Question about Golds Gym Trainer 410 Treadmill
Wont turn on after assembly
My husband and i just put finished putting treadmill together and it wont turn on at all as if there is no power
  • 21 Answers
Use a multimeter to check the power at the end of the power cord. This will tell you if the power cord is bad.
Next verify the power switch is lighting up. There is often a fuse between where the power comes into the machine, but before the lower board
Next issue would be the lower board. It is not uncommon for the lower board to bad out of the box if is a unit where the manufacturer requires the seller to first assemble and test the unit before a customer takes it home.
Posted on Jan 08, 2013
After putting together my sole f60 treadmill the display wont turn on, it gets a clicking noice, connections are connected. any idea where to start
Hook up the main harness . Make sure you didn't plug one of the connections up backwards. Hooking them up backwards will cause the incline to go all the way up and the display will not come on.
Aug 10, 2014 | Sole Fitness Sole F60 Treadmill
Whytouchscreen wont accept instructions
All touchpad problems on the Avanti treadmills are related to the touchpad membrane assembly that needs to be replaced and it is a common fault!!
Jul 12, 2014 | Avanti Fitness AT480 Treadmill
Bowflex error code H05
I recommend that you call the factory. They have bad disegned with the hardware, they can exchange the old board by new ones without cost.
Reach them and explain the problem. go to www.bowflex.com
God bless you
Sep 07, 2012 | Bowflex Treadclimber
I can't get my treadmill to turn on
1) test the wall outlet with another device such LAMP desk
2) test the c.breaker from your home if device is NOT turn ON.
3) If turn ON, go to reset the c.breaker or fuse replace, Try again.
4) Replace the power cord if is defective.
5) see the diagram attached for better troubleshooting.
Aug 27, 2012 | FreeMotion 750 Interactive Treadmill 12510...
Crosstrainer assembly problems
Most people will be able to relate to your problem, I have had many complications trying to put together home gym apparatus of kind or another.
It sounds to me as if the manufacturers do not product test their goods well before dispatch, so they assume that it will just fit all together if you have all the right bolts. If you have followed all of the instructions to the best of your ability, I would suggest contacting the supplier of the machine and ask for their assistance in putting it together.
If it is under warranty, then you should be able to ask for someone to come out and put it together for you for free. If not, then return the item and get it delivered for free under warranty in complete working order.
Jul 04, 2012 | Kettler ELYX 3 Elliptical Trainer 7654-000
I just put my tread mill together Nordic Track A2550 and the belt wont move
1) test your circuit breaker home,reset
2)test the outlet for 115 vac
3)test the power cord if some wires is loose or cutting
4)reset your circuit breaker insider from your equipment
5)Eliminate any extension cord from your treadmill.
6)Be shure if the receptacle have ground cable with your divided TRSS.
sincerely.
ERNESTO CUADRA
MANAGUA,NICARAGUA. C.A.
Dec 11, 2011 | Nordic Track NordicTrack A2550 PRO...
I had my treadmill in my office and it was working just fine, but when I went to puerto rico on vacation in June my husband and son decided to move the treadmill downstairs to the basement and now when...
To get an estimate on your repair, go to this web site http://www.searshomeservices.com/treadmill/repair?psid=92622610&sid=HSRx20100514x0017
or call 1-800-424-2047.
They will need some information on the treadmill, like year, make, model, part thats bad, etc
This is a good source for repair.
It from Sears.
Feb 25, 2011 | Kitchen Ranges
Rear Brake Assembly
Go to autozone.com Type in what car you have. then go to the repair section it will have a diagram of how to put it back together.
May 25, 2009 | 2003 Saturn L-Series
I need to know if I put it back together right
If you pulled it apart and put it back together but now it won't work properly, try checking your IDE cables to the hard drive/cd-rom, make sure they aren't connected backwards. Otherwise just carefully look over the entire board, be sure that the processor, heat sink and fan assembly are all intact and connected properly, do the same with the RAM, power connection, any expansion cards.
May 06, 2009 | Computers & Internet
Golds Gym Trainer 410 Treadmill Logo
234 people viewed this question
Top Golds Gym Exercise & Fitness Experts
Steven's...
Steven's...
Sock Puppet
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
