Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
Gld2250rdc1 top rack not getting water
Frigidaire gld2250rdc1 (same as Electrolux) not getting water on top rack. I removed arm alltogether, and even in TOP RACK washing mode - only bottom rack spinning, no water comes out of top rack's connection. How is water routed top vs bottom? Is there a valve or does motor spin different directions? where to look??
  • Dmitry Kukushkin
    Dmitry Kukushkin Jan 08, 2013
    digging further - water direction is controlled by ball blocking tube under filter in the dishwasher. not sure why - but the quick pause that dishwasher makes to switch - is not long enough for ball to change position any more....
  • patrick bossart
    patrick bossart Oct 14, 2013
    Did you ever find a fix for this issue? I have the EXACT same problem....
Frigidaire/electrolux dishwasher not cleaning top rack
There is a circulating pump that takes water from the bottom and pushes it to the top spinner. Most likely that pump is clogged or needs to be replaced. Replacement is a somewhat involved repair that requires removal of the lower pump assembly. It can be done DIY if you are comfortable with disconnecting a/c power to the unit, removing the unit and making tight hose re-connections. Before you do that - maybe check the intake for clogs that may be slowing the water flow. Have you routinely cleaned the bottom intake? (Most likely not ...) You can start by cleaning the bottom intake by usually removing the lower spin arm, then take out the catch ring and check for obstructions. The spin arm rests on a cap that can be removed to then remove the screen assembly. Be careful not to force the part in the wrong direction - with these you usually turn the spin cap right to unlock from the base. Then you can access the intake area - be careful as there are probably blades inside the intake that work as the disposal grinder. Remove the soap scum and buildup on all removal parts with a simple sponge and baking soda scrub. Do not attempt to run the machine with parts removed.
Sep 05, 2014 | Frigidaire Electrolux EIDW6105GS 24 Fully...
Why top arm is not rotating during wash in frigidaire/electrolux dishwasher
Check for clogged holes in the dishwasher arm. You might be able to use a strightened out paper-clip to unclog the holes, if they're not too bad. The other thing that would stop the wash arm from turning could be a build-up of calcium in the shaft or bearing of the wash arm. Remove the wash arm and clean it out manually. Then you will probably want to get and use a dishwasher cleaner, like Dishwasher Magic to clean out calcium you can't see or get to (easily).
Sep 05, 2014 | Frigidaire Dishwashers
Why are my top rack dishes not clean at all?
It is likely that sufficient water is not coming from the top arm. These dishwashers oscillate the water flow between top and bottoms sprays alternatively. This ensures water is pumped with adequate force. It is possible this mechanism is not working correctly. The device called check ball item 58 in this diagram actually does this function. The ball might be out of shape or not sitting properly causing incorrect wash water movement.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-FDB1050REC0/1428/0130000/R0505129/00004?blt=06&prst=&shdMod=
Apr 30, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
My frigidaire dishwasher does not wash on the top
Insufficient water can cause your symptoms
Nov 02, 2017 | Frigidaire Dishwashers
Top water injector not working
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 24, 2009 | Frigidaire 24 in. FDB126RB Built-in...
My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire FDB740RCS0 Upper Armnot Turning
the motor stops and runs in the opposite direction to pump water up to the top rack. you first need to listen for the motor to stop and start. if you hear that open the door and try to tell if water was coming out of the top spray arm.
Nov 01, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
75 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
