I can't find a replacement bulb for my Shift3 Lightblast entertainment projector.
The instruction manual says i should get a 55Watt, 12 volt, MR-16 replacement bulb. i can't find one anywhere. and why did it burn out after only 1 week of use?
Hi mcboo...
Amazon is the right place for you. click here Amazon com replacement bulb for projector and choose some. (do not forget to ask the seller if fits to your model)
hope this was helpful.
enjoy
Posted on Nov 19, 2014
Better buy new one (or used if its too expensive for you), because its not worth to buy just a bulb :/
here you can find new/used ones at good prices:
Amazon com Shift3 Lightblast
take a look
Posted on Oct 14, 2014
Click here Amazon com replacement bulb for projector and chose the one gfor your model. cheers
  • 3,904 Answers
I would try a company out of St. Paul Minnesota. They are called LPAV and they deal with equipment like this and hard to find items all of the time.
Posted on Jan 07, 2013
  • 1 more comment
  • mcboo66
    mcboo66 Jan 08, 2013
    thank you so much for telling me about LPAV. we are not positive that they have the correct bulb, but they think they have found it and will be shipping it to me. what a great company! i would not ever be afraid to send people their way! thanks!
  • Jerry Kramer
    Jerry Kramer Jan 08, 2013
    Glad to hear that worked our for you. The owners are friends of mine and I use them for my A/V business all the time.
  • mcboo66
    mcboo66 Jan 12, 2013
    just wanted to let you know that the bulb is perfect! LPAV has great customer service and i highly recommend them.
SOURCE: Replacement bulbs burn out within a month
If you did not purchase the OEM Sony manufactured bulb (model LMP-H200) then you likely acquired a poor quality "after market" lamp. I recently purchased a replacement lamp for my VW60. The list price is $369, I paid $269 from a reputable brick and mortal / on-line retailer.
If you paid substantially less than $269 or bought from an unknown on-line seller, your lamp is likely the problem. Note I have seen some shady on-line sellers (with "electric" in their name) sell knock of bulbs for the same price as the OEM.
Hope this helps.
Posted on Jan 26, 2010
fathitkf
  • 1871 Answers
SOURCE: infocus x2 burned out new bulb in one weeks
Hello :
Here I'll tell you how to replace it :
  1. Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
    It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
  2. In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
  3. Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
    Please note that in some projectors a small inside filter should also be replaced.
  4. Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
    Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
  5. Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
Warning:
  • avoid touching the bare projector lamp
good luck
rate if useful please !
Posted on Mar 13, 2010
  • 24 Answers
SOURCE: My Sharper Image entertainment projector
Change brand.
Posted on Mar 09, 2011
astig1977
  • 88 Answers
SOURCE: I've just replaced the lamp
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Posted on Aug 10, 2011
gopakumarg43
  • 74383 Answers
SOURCE: Need relacement buld for Brownie Movie Projector Model 1, bulb 300-watt, 120-volt,T81/2. S.C. bayonet base, C-13D projection lamp
Hello
You haven't specified anything about your projector or other detalis about it. jsut get into this link, and see whether the lamp you want is available there or not. You have to search with its number. It will have a model number on it. OK
http://www.visualapex.com/accessories/lamp-projection-tv.asp?MFR=DNGO
Posted on Dec 13, 2011
I have a Kodak Ektagraphic with no model listed on it at all. How can I find a replacement bulb, all I can find look wrong.
Supplied with 82V, 300W EXR lamp Projection Lamps Quartz-halogen 82 V projection lamps- Here is service manual link http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf Several different Models all say EXR 300W As CORRECT Bulb : EXR, 300 W (35-hour lamp life at full lamp/medium-brightness) Sampling of other lamps: EXY (200 hours/less brightness) EXW (15 hours/maximum brightness) FHS (70 hours/medium brightness) Use combinations of lamp brightness, plus half- and full-lamp settings to approximate image brightness in multi-projector presentations. Lamp Tips • Projector operation on line voltages above 125 volts greatly reduces the lamp life. • Unplug the projector before changing the lamp. • Allow for unrestricted flow of air to the exhaust vent to prolong lamp life. • Gently wipe off any fingerprints with a soft cloth moistened with rubbing alcohol.
Jun 27, 2016 | Kodak ATS Ektagraphic Slide Projector
Can we still buy a bulb for an Agfacolor 50 projector?
Most bulbs (regardless of vintage) can usually be found at a number of places: you can also try a retail chain called "Batteries PLUS Bulbs". The 3-letter ANSI code that identifies the lamp (can be found on the top of the old lamp, the base of the lamp or in the projector's manual) will make the search simpler. I just did a quick search on "Osram 64610" and found the code to be "HLX", 50 watt, 12 volt. Found a few on Amazon for under $4 each. Happy Hunting !!
Nov 19, 2014 | Office Equipment & Supplies
I have a merch source lightblast projector model 1635224. I replaced the blub and it still does not work. Is there a manual somewhere?
Stop buying burned-out bulbs. Whatsamatter4u? Buy a $9.99 voltmeter and see if there's power where there should be. C'mon, learn a bit of techie stuff...
May 15, 2014 | Cameras
Cant change the light bulb
Consult the owner manual or Google the model number to locate one which will have instructions for replacement of the bulb.
Nov 02, 2012 | Sharper Image Entertainment Projector...
Lightblast entertainment projector light does not come on
You can get a manuel at MERCHSOURCE customer service-i found the label on the underside of the projector and searched till i found a customer service link!!!!merchsource1635224 manuel was what i searched and went to
mscustomercare.com the original manufacturer!!!
Apr 22, 2012 | Air Tools & Compressors
I have a Revlon lighted make up mirror, model # RV-961/RV-961F. I threw away the manual and need a replacement halogen bulb 12 Volt or higher. It has three level of lighting but I'll settle for the...
No!,No!, No!, Not 12 V and higher.
It is a 12 Volt bulb with 50 Watts or lower
Hard to remove bulb. I did and exchanged it and still no light I will buy another mirror. Cheap enough.Bed Bath and Beyond sells them.
Jul 24, 2011 | Revlon Health & Beauty
I need a replacement bulb for t3606 12 volt, 20 watt, 1.7amp
I'm glad to provide the instructions get the replacement Spreader Light. Please click hear to order for the Spreader Light.
Please let me know if you require any additional help.
Jul 12, 2011 | Guest 410 Marine Compact Spreader Light...
Thinking about purchasing the Shift3 Lightblast Entertainment Projector. I know that this system can project video games and movies but can it also project TV programs such as football, basketball games,...
Perhaps you meant can it project sports *well*. Of course it can display any standard signal. If it can display TV and video games, it can display sports. However, the resolution and aspect ratio of the device is standard definition. So it is 4:3 and equivalent to VHS tape. If you have an HDTV at home and are expecting to be able to see the small print on the score graphics, forget it. But for the price, it does a great job of projecting a picture.
Sep 13, 2010 | Televison & Video
Sharp projector lamp will not come on
It is mother board problem.Reverse side of the board 5 pin ic not giving 12 volt.pin no. 1 input 12volt and pin no.3 12 volt out.it might be damage
Feb 26, 2010 | Sharp XR-10S DLP Projector
864 people viewed this question
jasbo
jasbo
