Question about Electrolux 23 in. ESL6114 Built-in Dishwasher
How do i refit the door spring in electrolux dishwasher
Hinge was broken , replaced same but am struggling with refitting the spring
  • Official Brand Answer
  • 4,342 Answers
Hello pxdaly- I will be happy to assist you, however in order for me to assist you better in pinpointing you the information; may you please provide me the model number?
Posted on Jan 10, 2013
3 Suggested Answers
SOURCE: I have a electrolux dishlex dishwasher that has a
I got a small flat head screwdriver and placed it between the door and the body of the dishwasher, I then got a bigger screwdriver and gently put it in the space created by the smaller driver and gently pushed down to release the door !!!
Posted on Oct 13, 2009
  • 4336 Answers
SOURCE: dishwasher powder cap not opening to release the
be sure the rack is not installed backwards. One direction has an opening and the other has a rod that blocks the door from opening.
Posted on Oct 06, 2010
Door lift spring came off how to put it back on
the spring will be at the lowest tension when the door is in the raised position
there should be an adjustment at one end where the spring is attached to adjust the ease to lift the door and hold it open so if thee is loosen that adjustment off and with the door held up ,refit the spring
Oct 22, 2015 | Hobart Used AM14 Pass Thru Commercial...
How do I fit a door catch Electrolux dishwasher esl63010
Usually with door open there is 2 screws holding the locking assembly in place! Undo all screws and remove whole assembly! Refitting is reverse!
Oct 13, 2014 | Dishwashers
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
Aug 10, 2011 | Fisher and Paykel 24 in. DS603H SS...
How do I refit the door on my WM77p? I've replaced the hinge & hinge bearings but as soon as I removed the old hinge, the backplate dropped down into the casing. I've managed to retrieve it but what do...
Hi Geoff, If you remove the band around your door seal and then you will be able to just remove part of the seal frrom the casing. I am sure you will manage to refit door quite easy then. should take about 5 minutes then.
Feb 25, 2011 | Hotpoint Washing Machines
Our Bosch electric oven is 5 years old. We
Either you have not refitted the door back correctly, or the door hinge springs are weak, a common problem.
This being the case, then the only solution is to replace door hinges.
Feb 11, 2010 | Bosch Ovens
I have taken the Door off to carry out cleaning,i am aware how to put the lugs on but the door is still open at the top
You may possibly not got the hinges relocated properly.
Take the door off again, and refit, if still gap at top, then you will have to replace both the door hinges,asit is probably weak springs.
Hope this helps.
Dec 18, 2009 | AEG B8139-4-M Electric Single Oven
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
Electrolux EOB5630 door hinge locked closed
Look for a release button. If not, it may have a locking mechanism that needs to be released. Try some of these: push the hinge to one side while lifting, press the hinge down then lift, pull up on the hinge while pulling. Good luck!
Oct 24, 2008 | Electrolux EOB5630 Ultrafan Electric...
The oven door won't close properly, it just hangs slackly about 2 cm from the seal. it's a smeg wall oven.
the clips on these oven are canyilver type they can move out of position if opened abruptly .to refit correctly lift door upwards while pushing the bottom of the door inwards.you should feeel a strong resistance from the door springs.there should be a notch n the bottom of the hinge this should slot over the oven frame.if this does not solve the problem then the springs have probably gone on the hinges and will need to replace both hinge assemblies
Jul 11, 2008 | Smeg Kitchen Ranges
Electrolux 23 in. ESL6114 Built-in Dishwasher Logo
97 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Gerard Curran
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
