Question about Asko Dishwashers
My Asko D1996 Dishwasher will not start. The control panel has 3 lights staying on - position #1, 6 and 7 and are unresponsive no matter what buttons are pushed - even after turning the power off at the breaker, the outlet and the on/off button.I've tried holding down the start button for several seconds to reset but this did not work. I have also cleared the drain, filters and removed any water and pushed and held the Start button to reset.
fgainer
  • 54 Answers
SOURCE: Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Posted on Feb 02, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
SOURCE: Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Posted on Sep 18, 2009
VtToolMan
  • 704 Answers
SOURCE: Can't start the dishwasher, lock button is lit up.
Hello Albert, On the Jenn-Air dishwasher you have, you have to hold down the "Heated Dry" button for 3-5 seconds to unlock the control panel.
This should unlock the controls so you can again use the dishwasher normally.
Since you''re likely going to have this dishwasher for some time, I've included a link where you can download a free owner's manual for it.
I would print out a copy for your future use and reference. I also have a file on my computer that I title "Home Appliances and Equipment" which is where I download and save an electronic copy so I always have a backup copy saved, since manuals aren't always readily available on the web, as the appliances get older.
http://www.jennair.com/assets/product/6_920374_A.PDF
The info on locking and unlocking the dishwasher can be found on page 13 of the manual.
I hope you find this Very Helpful and best regards!
Posted on Nov 23, 2009
Testimonial: "Thanks for the detailed info about my question, VtToolMan, I greatly appreciate it. However, I tried to unlock it that way, but it didn't work. "
SOURCE: Reset control panel for Whirlpool ADG 4952
whirlpool adg4952m is reading F2 and not working
Posted on Jan 12, 2010
Rinse aid dispenser not working
You have to take apart the whole door panel to see what the problem is,.
Jun 07, 2013 | Asko Dishwashers
Asko D1996. 2 wet spots on floor in front of unit, (~1/2 cup). It continued to run, but the inside bottom of the machine was dirty, as though it slowly drained its wash water. Dishes mostly clean..
If you can open the panel and allow the panel to dried then tested to confirm before the panel is removed.
Use a hair dryer or a good air jet to remove all moisture from the panel and see if this works.
Oct 27, 2011 | Asko D1776 Stainless Steel Built-in...
Asko D1996 dishwater does not turnon.
Check inside the machine for fuse or circuit breaker. Replace or reset. If repeats, you have to contact the service center.
Apr 14, 2010 | Asko D1996SS Built-in Dishwasher
Asko D1996 lights flashing washer won't start
I'm having the same issues. What did you do to solve yours? My start button never lights up! Thanks for your help!
Oct 01, 2009 | Asko D1776 Stainless Steel Built-in...
My ASKO D1996 Dishwasher will not turn on, checked the power and it is running, but no lights or anything turns on. I don't have the water connected to the machine, could this be the problem?
NO, you should get light actions even if the water was not connected. this is a main control issue. there is a control board kit available for your unit. you will need to replace this damaged control in this case. the logic sector is damaged.
Jul 19, 2009 | Dishwashers
Possible causes
3. Fuse has blown.
Feb 02, 2009 | Asko D1996SS Built-in Dishwasher
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Sep 10, 2008 | Asko D1706 Built-in Dishwasher
My problem is with a Asko D1996
Remove the panel down on the backside of the machine. Dry ut the water on the bottom pan with a towel or so. Should work like new;)
Jan 27, 2008 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
111 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
