Question about SanDisk Sansa e250 MP3 Player
Random restarting Soo, my sansa is acting up [when is it not?]. It won't play certain songs that it would play before, and every once-in-a-while, it restarts. Any help would be much appreciated.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
My Sansa Fuze won t recognize certain songs
you need to check the format the songs are in, try putting them in mp3 format
Mar 28, 2010 | SanDisk Sansa Fuze MP3 Player
No songs can be added
The songs that you are trying to load are probably in the wrong format. Many WMA files (used by 90% of music services) have restrictive DRM licenses that will not allow you to play certain files on an mp3 player, even though they play fine on your computer. Also, the Sansa e200 does not play songs that are in iTunes format. If you stick only to songs that are in mp3 format, you will not have such problems.
If you are CERTAIN that ALL of your songs are in mp3 format:
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa e250 MP3 Player
Can't delete songs that don't play
Run the Sansa Recovery Tool and just start over from scratch. Only use songs that are in mp3 format if you don't want grief later.
Dec 27, 2008 | SanDisk Sansa E280 MP3 Player
MY SANSA WONT PLAY SONGS, IT SHOWS ARTIST BUT STUCK IN PAUSE
Some songs are in the wrong format, or your DB is corrupt. Either way:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
-Tha Mp3 Doctor
Dec 16, 2008 | SanDisk Sansa Clip MP3 Player
MP3 not playing the songs and gets restarted
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Oct 15, 2008 | SanDisk Sansa e270 MP3 Player
Random play of songs
it is normal - check the firmware upgrade to see if it iso ne of the issues that the firm upgrade resolves
Jun 19, 2008 | SanDisk Sansa e250 MP3 Player
My Sansa e280 randomly restarts.
Try to reset it and reload the firmware.
Apr 01, 2008 | SanDisk Sansa E280 MP3 Player
Won't play certain songs
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Oct 31, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
