Question about Aqueon Mini Bow 5 Gallon Aquarium Starter Kit
My filter is buzzing but no water is going through
The filter is continuosly buzzing and no water is coming out, i tried washing the filter sponge and still nothing
    Guru:
  • 154 Answers
I have this issue with my filter when I unplug it. Occasionally, I can hit the side of it a few times and it will work. The issue is that something is blocking the inside and preventing the impeller blades from spinning freely.
To fix the issue I usually do three things:
  1. I remove the bottom pipe from my filter and tap it on the ground to free the blockage.
  2. I also run water from my sink through it to clean it out.
  3. Lastly, I use Q-tips to try to get in there and remove the gunk (I have a small filter).
Time Spent? I have spent anywhere from 5 minutes to an 1 hour cleaning out the filter with the above techniques.
Advice: Change your filter cartridge every 2 weeks or when it's covered. Don't unplug it if you can help it!
Best of Luck!
Posted on Jan 25, 2013
Model MEX731CAS1 stackable. Why doesn't it drain the water and there is a burning smell when it's on?
My guess is that some of the sponge has got into the drain pump. Open the filter at the bottom of the machine and clear it. Beware water will come out onto the floor when the filter is opened. The burning smell may be the pump motor or you could be lucky! Hope this helps.
Feb 01, 2016 | Washing Machines
Air filter is water wet and will not start
is filter sponge coz water on it will act like a choke is on and over fuel !? if yes then remove it and take sponge off its frame and wash in petrol to clean out water and dirt , squeeze dry and towel dry , then lightly coat filter with oil and replace on bike !
Mar 15, 2013 | Husqvarna CR 125 Motorcycles
What's a sponge filter?
In sponge filters water is forced through porous foam. Water flowing though the sponge allows the growth of a colony of beneficial bacteria which neutralizes toxic ammonia. Most sponge filters uses two sponges attached to one lift tube which is an advantage that the sponges can be cleaned one at a time, reducing bacterial loss.
Aug 09, 2012 | Fish
How do i take off straps to clean or wash them
Good Afternoon
The harness straps are attached to the sub seat (seat frame) of the Buzz and do not come off.
To clean them, remove the seat fabric to expose the entire length of the harness straps, and use a bowl of warm soapy water and a sponge.
Aug 19, 2011 | Quinny Buzz Three Wheel Stroller
How do i wash my filter on my dc08?
There are 2 filters on your dc08 the one that is under the bin is sold as being lifetime which I strongly disagree with. I work as a vacuum Technician and I would strongly encourage you to buy a new exhaust filter every 2 years. The filter at the top of the machine can be washed in normal tap water. The filter is in two pieces, the blue sponge part can just be squeezed like a kitchen sponge the other part with the colored plastic casing can be gently scrubbed with a toothbrush or similar. It is important to remember that the more often you wash the sponge part the less often you will need to was the cage. If you need to buy a new Dyson washable filter because yours won't come clean they are only $20 so just visit NelsonVacuums or VacuumSpot and have one delivered.
Feb 11, 2011 | Dyson DC08 Hepa Allergy Bagless Canister...
Where is the air filter? How do I clean it?
The air filter should be connected directly to your carburetor.It should just be a sponge in a container connected to the carburetor.On most mowers it is one screw to remove the cover.You remove the sponge,and clean it with soap,and water.Dish washing liquid should work fine.squeeze all the water out of it.then soak the sponge with motor oil.then squeeze out most of the motor oil.The motor oil traps the dust.Then put your slightly oily sponge back in its holder,and close it up. Your done.
Jun 05, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Vacuum cleaner filters
Sponge filters should be washable. I have found that "FLASH" lemon floor cleaner is by far the best, but washing up detergent will do (far too many bubbles to get rid of for my liking!). I find pouring the detergent onto the sponge and working it in before dunking it in very warm water works best. Despite not being very washable, most paper filters can be washed if you have no other choice and you take care. Just pour on cleaner and then dunk up and down in hot water. Then leave in the airing cupboard for a couple of days to dry. It should get you by until you can find somewhere to buy a new paper filter.
Jan 23, 2009 | Vacuums
HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Aqueon Mini Bow 5 Gallon Aquarium Starter Kit Logo
337 people viewed this question
Top Aqueon Fish Experts
john h
Richard Lindsey ...
Steve Dearman
Level 1 Expert
Are you an Aqueon Fish Expert? Answer questions, earn points and help others
