Question about Thomson Televison & Video
Thomson flat panel tv has sound but no picture (comes on for about a second then goes blank)
If I change the source (from TV to DVD) then picture appears for about a second but then goes blank. Sound comes through all the time.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 182 Answers
If you can see if the screen lights from behind when the picture apears for a second then the problem is probably the invertor or worse the screen
Posted on Sep 24, 2013
premtech
  • 934 Answers
SOURCE: no picture on flat panel tv. has sound
Sounds like the digital control board, 6871qch038a Lg Digital Control Module subs to 6871qch038c. But that's just a first something I would check in this unit. Replace also capacitor C19, 630V big blue square cap very common failure for no video. You might want to shop this one thee are a host of problems with this unit that would certainly get some needed attention if a qualified tech were testing it and looked up the bulletins.
Good Luck!
William Rayburn, CET
Premium Technologies
Posted on Oct 05, 2009
SOURCE: flat tv, sound but no picture. have tried
I had one that had a black screen and fixed the problem by repairing the inverter. When I opened the unit I looked at the capacitors on the inverter board and found them swollen. I looked at the bottom of the board and found that the fuse had opened up. The caps were a cheap quality low temp variety 150uF at 25V I replaced them with 330uF 25 volt 105C caps. I then replaced the 2.5A surface mount fuse with an axial 2.5A pico fuse and the TV worked beautifully.
Posted on Jan 08, 2010
  • 50 Answers
SOURCE: Sound but no picture
no bulbs to replace here, i might have better news for you. Toshibas with this time frame has an inverter problem. turn tv on tilt back wards at 45degree angle and flack a light to the screen and look closely if you can see the image the replace the inverter units. to help you see hit menu on remote, the menu is white so will make it more visible. If you did want to replace the inverters they are like 60-80 $ for hte pair and simple to replace.
Posted on Apr 27, 2010
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
budmrtn
  • 11361 Answers
SOURCE: Picture comes on for a couple seconds, then goes blank
You may have bad 24vdc power supply or bad back light inverter boards.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 30, 2010
Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Jan 15, 2010 | Thomson LCDB 03B 27 in. Television
42" LCD TV no picture.Have sound
inverter panel is faulty you can probably source another via ebay if your confident on fitting it could be expensive otherwise
Dec 12, 2009 | LG 42LG50 42 in. LCD HDTV
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Westinghouse 42' tv working fine this morning, got home from work this evening turned tv on picture come on for about 4 seconds than blank screen still had sound pressed menu botton still blank screen...
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 01, 2009 | Westinghouse Televison & Video
Hitachi 65F710 tv goes blank for a second...
sounds like a possible flex module problem. repair is usually abut $500- $600.
Apr 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Maxent MX-27X2 no video,but sound
may not be the inverter but the main board bad
nesco
Dec 30, 2007 | Televison & Video
Thomson 27" LCD TV 27LCDB03B
cannot be presise but at worse the lcd back light is failing or the supply to it . this is a job for a service engineer
Dec 02, 2007 | Thomson LCDB 03B 27 in. Television
Televison & Video Logo
149 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
