Question about Pool & Spa
Hayward FLO-SELECTOR - SP-740DE 2 inch manual
  • 61 Answers
SOURCE: using a hayward vari-flo valve model SP 710x32
Do not drain a vinyl liner pool mor than half way....ever... If you have a fiberglass, or gunite pool it is important to pull the hydrostatic plug under the main drain cover. If you live down a hill, or where there is a high water table, the water pressure underground can lift the empty pool out of the ground (more common in fiberglass pools). If you have a sand or DE filter switch the valve to waste. make sure that you have the skimmer turned off, and the pump is only sucking from the pool main drain (spa drain closed also), and turn the pump on. Make sure the waste hose is far enough away so you dont add any hydrostatic pressure.
Posted on Apr 04, 2009
john224
  • 1378 Answers
SOURCE: Hayward vari flo valve
It will not be glued, it is just stuck in there good. You will need to scrape, pull, twist or otherwise convince it to come out as best you can and then clean the area well before installing the new one.
Posted on Jul 17, 2009
Coastsider
  • 331 Answers
SOURCE: How can I find the installation instructions for
http://www.haywardnet.com/inground/products/displayProd.cfm?ProductID=66
Posted on Apr 14, 2010
  • 990 Answers
SOURCE: 2nd Hayward Max Flo 2 hp pool pump stopped working again!!!
More than the motor it is probally a bad seal causing the problem with the motor. All you can do is be sure it is installed right when you put the new one in and if you see water under the pump take it apart and install a new one. I live in AZ and the water will evaporate before it gets to the ground under the pump so here this can be a real annoying problem. We quite often will have to look for calcium left behind when something leaks.
Posted on Jun 27, 2010
MOTORWIZJ
  • 1349 Answers
SOURCE: turn filter on, pump turns on then trips breaker?
NOT A MOTOR TO TAKE LIGHTLY 2 SPEEDS ARE BIG $$$ . TAKE 4-6 . 9/16 BOLTS OUT OF PUMP DISCONNECT POWER (LOOK) WRITE DOWN COLOR OF WIRES AND PLACE THEY GO TAKE PICTURE ! ! AND DO NOT TRY TO TAKE ANYTHING ELSE APART ! SEARCH FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING USE YOU ZIP CODE IN YOUR SEARCH .COULD BE JUST A BAD BREAKER BUT NOT WORTH THE CHANCE..HAVE A PRO LOOK AT IT. BEST OF LUCK .. VOTE IF'N I WAS OF HELP
Posted on Aug 03, 2010
SP-1510-Z1-XEHC
bad motor on pump need a new one
Jul 06, 2014 | Hayward 1hp Power Flo Matrix Above Ground...
Sp-1510-z1-xehc above ground DE filter. How much DE
the part number you listed has nothing to do with a DE filter. try again
Jun 23, 2014 | Hayward 1hp Power Flo Matrix Above Ground...
I have a Hayward Power-Flo LX SP1515-Z2-EBK3 that is being used to pump water through 2-4x8 solar water heater panels. The pump intake is 1 1/2 inch, discharge out is also 1 1/2 inch. The pump is located...
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Gary
Sep 06, 2011 | Hayward Power Flo Lx
How do I take my hayward Power Flo Matrix pump apart to replace the shaft seal?
The instructions are in your owner's manual, which you can also find on Google. No specialty tools are required.
Aug 04, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
What impeller does the # Sp 2815x20 use
It uses the SPX2610C impeller. We sell it for $24.26 and have 2 in stock if you need one.
John
www.arrowpools.net
Sep 09, 2010 | Hayward Max Flo 2 H.P. Pump #Sp 2815x20...
Turn filter on, pump turns on then trips breaker?
Jul 24, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Three pvc pipes coming into an max i flo pool pump should all three valves be open to run the pump?
Here is a link for the users manual for these pool pumps. You should be able to not only see a diagram, but also read all about which valves should be open and which closed.
http://www.backyardcitypools.com/images/hayward/power-flo-manual.pdf
Jun 19, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Replacement parts not matching # in Hayward Power-Flo manual
I would think so. It is probally a newer model with heaver ribs or stronger plastic. They find weakness in these and fix the newer ones. So I would guess so.
Apr 24, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Pool & Spa Logo
186 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
