Question about Pioneer 2012 Deh-3400ub Cd Usb Ipod Iphone Car Stereo Deh3400ub Deh-4300ub
Pioneer deh-3400ub head unit will not power up
Checked the 10 amp fuse it is ok. power is getting to the harness, but unit does not turn on.
5 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: NO POWER TO PIONEER HEAD UNIT
Disconnecting the cables shouldnt have hurt it. Make sure you got the plugged back in ALL the way and try again. Post results here.
Posted on Sep 12, 2007
james klgr
  • 362 Answers
SOURCE: Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Posted on Dec 12, 2007
merle840
  • 113 Answers
SOURCE: my pioneer deh-1900 mp will not turn on
did you use a wire harness adapter or did you connect the wires from the radio directly to the wires in the car? do you have a computer safe test light or a digital vom meter? do not use a conventional test light in this car or an analogue meter to check for power
Posted on Apr 04, 2008
SOURCE: Pioneer deh 2300
if you were in augusta,ga i would give you one.i have a lot of them.... pioneer is the only cd player
i use
Posted on Sep 25, 2008
Headlight won't turn on
sounds like your fusible link blew .part of positive battery cable
Oct 16, 2015 | Cars & Trucks
Speedometer and odometer not working , harness is ok and checked fuses and seem to be ok
The Speedometer has been known to go bad. But if you check the SIGNAL fuse in the fuse block behind the left rear engine cover you may find it open. Replacing the 10 amp fuse should get it working again. Don't just measure the fuse's voltage test points, pull it and look at the fuse itself.
Mar 14, 2011 | 2005 Suzuki Boulevard C50
Electrical problem
The main fuse is located on the starter solenoid. Have you checked that fuse. Perhaps the damage is part of the solenoid , did it get hot and partially melt. This is a common problem. There is also one single 10 amp fuse under the seat off of the main wire harness. Hope this helps.
May 17, 2010 | 1982 Honda GL 1100 Gold Wing
No power showing on display board, checked electrical hookups it ok. Outlet has power. checked child tamper and delay no response
its the fuse, its located under the dishwasher. take off the bottom white plate, its on the right side of the pump on a wire harness. Its in a fuse cartridge turn to the left take out fuse and replace with 15 amp fuse take it radio shack and have it matched.
Mar 03, 2010 | Samsung DMR57LFS Stainless Steel Builtin...
I turned down the volume on my kdc-mp522, when i went to turn it back up, it was off (I did not stop or turn car off.). I cannot get it to power on, i can insert and remove disc, so there must be power,...
that is kind of strange and if your getting power to put a cd in but no for it to fully power the unit you may need to check another fuse it will be not be your radio fuse but instead a mini fuse in your vehicles cabin should be on the left side under neith the dash or on the side of the dash it will most likely be a 10 or 15 amp mini fuse that supplies power from the fuse box to the reiceivers acc source ignitions source
Nov 11, 2009 | Kenwood Sirius KDC-MP522 CD Player
Our polaris sportsman 500 6x6 won't start
Polaris seems to have a problem with this issue. I had the same problem with my bike and was able to fix it . I found a bad resetable fuse link located under the front cover. It looks like a plastic case with wires at both ends. cut the case and check the condition of that part. I found it was badly rusted . I removed the part and wired in a 10 amp fuse with a holder. wrapped it up to protect it and the problem was gone. lights worked fine as well as the cluster. Ed.
Oct 11, 2009 | Polaris ATV
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
RUUD UPGH air/furnace just quit....no response...where to begin?
is the power light on the board lit? IF NOT THE 3 AMP OR 5 AMP FUSE COULD HAVE BLOWN ON THE BOARD
Apr 27, 2009 | Heating & Cooling
06 hyundai monsoon radio won,t turn on.
Just got an update from a dealer that might work...take the head unit out and unplug the power for about 30 sec. plug back in and the unit should basically reset itself. If that doesn't work I'm out of guesses.
Dec 27, 2008 | 2006 Hyundai Santa Fe
1997 k1500 just quit and will not start
you should have power on the tan wire for about 5 seconds with key on try to cycle key on for 5 sec off for 10 sec if no power chehave power on both sides of fuseck ecm 1 10 amp fuse if you check ecm b fuse if that is ok check for power on the orange wire and power on the green with white wire on fuel pump relay if you have power on those check for power on the grey wire out to fuel pump if you have power on grey wire you have a bad wire from the grey to the tan wire some where in the harness hope this helps
Nov 16, 2008 | 1997 Chevrolet K1500
Pioneer 2012 Deh-3400ub Cd Usb Ipod Iphone Car Stereo Deh3400ub Deh-4300ub Logo
77 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
