the end programs means that some program is running while you are shutting down you have close all the program before shutting down you can just click end program or wit for the process to end by itself to know which program is running while you close press CTRL+ALT+DEl click the file you will see the program which are running go to shut down and click shut down its shut downs and the end program stops coming
It is possible that the auto defrost timer is faulty and must be checked.Once the compresoor has been shut down and restarted the timer should shut down the compressor and defrost connecting the heaters.Hence check timer heater and also the thermostat(it must shut down at low setting).
no is this ur printer is laser or inkjet means because of low usage one the printer will be on but no usage so try uninstall the print drives install newly and then try sitll it has problem means problem is with the main board
SAME ISSUE!! Any help on why?
