Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Panasonic PT50LC14 No Sound or Picture
No picture and no audio. replaced obvious bad lamp assembly. Put in new unit and tv momentarily started (a bit of light and a bit of sound) and then went dead. The green start light flashes for a while then turns red and flashes. the smaller red light flashes about once every 5 seconds.
Bad new lamp? Bad ballast? Help.
  • Anonymous Mar 27, 2014
    new lamp no picture, there is a buzzing sound when you turn tv on
  • 37 Answers
Unplug it, and let it set for a minute or 2, then try it again...if it does it again hit the power button again to turn it back on...also once the the tv turns on make sure you reset the counter for the bulb..that will also cause reset the counter press the (-) volume on the tv while holding down the (-) press spilt,pip on the reomte...the lamp will reset and the indicator will go out
Posted on Mar 12, 2009
I have a wd-57833 work good I got the same one from some one put in a new lamp tv work for 5 hr then stop working on sound or picture but the lamp is good i put in in my tv and it works so i put the p
If the lamp is new and good to go then you may have to reset the lamp replacement counter in your setting menu. When that is set back to zero you wont have a problem until it is time for a new lamp again.
Aug 19, 2014 | Mitsubishi WD Televison & Video
PT-50DL54 50 in. Rear Projection HDTV-Ready Television: started to get dimer and dimer and finally picture...
You should have received a message on the screen about replacing the lamp. Also, the LAMP led on the front should be lit in red.
You can replace the lamp assembly easily for about $150 - $250.
Don't try to replace the bulb only.
A new Panasonic Plasma TV will cost about $1000 and good for another 5 to 6 years.
May 05, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Removal of the lamp unit from the tv
sometimes lamp is replaced in the front of tv.If so the panel under picture pulls out revealing lamp housing which is held in with a couple screws.replace lamp housing assembly
Feb 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic projection tv model # pt56lcz7 no picture, bulb out?
This unit does not have the usual lamp assembly that most do. On this unit the whole light engine has to be removed to replace the lamp assembly. Part number is LFS4000PA1 and cost is $1,351.95 @
Sep 01, 2009 | Panasonic PT-50LCZ70 50" HDTV
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT50LC14 Rear projection LCD - too much green
Had the same problem today. Thought is was my bulb. Replaced it but still had the color problem. Replaced the cables between cable box and TV and no more problem!
Jan 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Green light flashing & no picture on Toshiba 40pw13p
There is problem with the lamp. It might need to be replaced. The lamp unit is on the bottom-left side of your TV. Loosen thumb screw (by hand) to take the the lamp unit door. Using a screwdriver, loosen two screws of the lamp unit and carefully pull the lamp unit out.
Put a new lamp in reverse order.
Jun 28, 2008 | Televison & Video
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Green Power light blinks but no picture or sound with a chirping noise
That chirp is your ballast trying to fire the lamp. Sounds to me like you need a new lamp. The model should be TY-LA1000. Keep in mind though that the ballast could also be faulty, but 85% of the time it's a lamp. Pull the cover off the unit and remove the lamp. More often than not, when the lamp goes it'll actually break and be obvious.
Dec 12, 2006 | Panasonic PT50LCX63 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
388 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
