Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Toro 5/24 snowblower will start but dies when i start throwing snow
Had the same problem with my toro blower 5/24 and small engine guy told me that there is a screw underneath the carburator adjust it out (left) about a quarter of turn. I did that and the blower ran good for awhile but it is starting to run rough again so I think I will take it in and have it tuned up. It sounds to me like a fuel delivery problem, could be some gunk in the carberator. TW
Posted on Jan 10, 2013
Wont throw snow is there a belt adj
the idler pulley might have a slot to adjust more tension
Feb 17, 2014 | Toro 826OXE 2-Stage Snowblower 38624W
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
Won't start
The carburetor on your Toro 418ZR snow blower is located on the right side of the unit above the rear wheel (if standing behind the snow blower). You will have to remove the top main cover and the starter housing to access the carburetor cover and assembly. Here's a part diagram that may help out: http://www.jackssmallengines.com/Jacks-Parts-Lookup/Manufacturer/toro/5860/62997
Dec 15, 2013 | Toro Power Clear Snowblower 418ZR - 38272
Torro snowblower won't throw snow. Gets stuck in auger and blades.
make sure its turning a good speed, check belts
now that you have all that other junk on it it will be hard to do what you should have done. paint those parts. then spray with wax pledge will work. I buy and resell these and it works for me. nny
Dec 14, 2013 | Toro Power Clear 221 Electric Start 21...
Toro snowblower wont start. seems like the fuel isnt getting into carb.how and what can i do
Reference your toro snow blower. does it start and run for a few swconds then die. if so It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now.
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
The engine starts but won't actually throw snow the wheel that turns to throw snow is not turning
There is probably a shear pin or bolt that has broken, providing all other belts and accessories are intact. Should be very simple to take the bolt out of the wheel where it attaches to the shaft. Just take it to a hardware store or an outdoor store that sells snowblowers.
Feb 17, 2010 | Toro Lawn Mower With Toro Power Tools
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Huskee Snowblower has to be constantly at high RPM to throw snow
It sounds like the sping that goes from the throttle lever to the govonor arm is either streched or broken.
Jan 20, 2009 | Toro Blowers Rake and Vac - Electric...
Will not throw snow
I have a toro 421 snowblower won't start after had it fixed from shop and how to operator to starter?
Jan 15, 2009 | Toro Lawn Mower With Toro Power Tools
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
174 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
