Question about Sony PlayStation 2 (PS2) Console
Disc error I have a game on gamecube and when I get to certain point in the game it says error disc cannot be read how do I fix i have tried cleaning it to but i didnt do anything
Hi i will tell u what to do put the disk good it is very easy
Posted on Jan 21, 2009
I inserted my game and it said "the game disc
Single Disc
The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
  1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
  2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
  3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  4. Check for specific game issues. Some games may have known issues or game play elements that appear as problems.
  5. Ensure the game is being loaded properly. With the power turned off on the system, replace the Game Disc (label side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
  6. Look for obvious physical damage to the disc. Remove the Game Disc and check the non-labeled side for cracks, scratches, smudges, or dirt. The Nintendo GameCube has extensive error correction capabilities and minor scratches or contamination should not cause issues in most cases. However, it is important to determine if disc damage is causing the problem.
    • If the disc is cracked
      Review our disc replacement policy to determine how to get your game replaced.
    • If it's dirty, scratched, or shows no obvious damage
      1. You may try cleaning the disc again with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
      2. Make sure the game is dry, then re-insert it and see if the error occurs again.
      3. If the game had been working normally, shows signs of physical damage, and now displays errors or lockups in areas it previously didn't, the problem is likely to be the damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
      4. If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.)
  7. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance
Feb 20, 2011 | Nintendo GameCube Console
I have a gamecube.on the game smashbrothers,it will play for a few moments and then it says:can't read disc,refer to gamecube manual but i don't have one.please tell me what to do.
If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 begin_of_the_skype_highlighting 1-800-255-3700 end_of_the_skype_highlighting for assistance.
Jan 19, 2011 | Nintendo GameCube Console
The game disk could not be read.
It sounds like the disc reader is dirty, it's the little clear circle right under where a disc would go, closest to the back of the unit.
To clean, open disc cover, locate the disc reader, use a dry soft towel or some toilet paper and gently wipe it off, sometimes even a little dust can cause a problem. This should do the trick. If it doesn't, then either the disc is scratched or the Game Cube has something wrong with it.
hope this helps!
Sep 20, 2009 | Nintendo GameCube Console
My wii won't read any discs.
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide......
Mar 27, 2009 | Nintendo Wii Console
Wii unable to read gamecube disc... :(
Mar 23, 2009 | Nintendo Wii Console
My gamecube wont read my game disc
Its either the game disc or the lens of the gamecube. Try cleaning the disk or try another disc. If the cube still doesn't read the disk your lens is probably scratched in which case you would need a new gamecube.
Mar 07, 2009 | Nintendo Mario Kart: Double Dash for...
Disc reading error
you might want to take it to either a video game store or a movie rental place and see if they can resurface the disk for you might cost a couple of bucks but ushally they will do it. It might help but about the only thing that I can think of to solve this.
Jan 20, 2009 | Nintendo GameCube Console
Unable to read disc error
If Wii gives Unable to read Disc Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Nov 10, 2008 | Nintendo Wii Console
Games initial load before Play Starts receive error 'cannot read disk see instruction manual'
If this happens for only some games, you should try cleaning the discs with a disc cleaner. Otherwise, you could try asking around at stores like circuit city, radioshack, best buy, etc. for what you could use to clean the lens, the part that reads the disc in your gamecube. If that doesn't work, chances are that the lens is damaged and your only hope is to send it in for repairs or get a new gamecube (or Wii).
Oct 13, 2007 | Nintendo GameCube Console
GameCube Problems
If this problem occurs for every game you try, every time, then it is most likely a hardware failure, and you will indeed need to contact Nintendo for repair information. If it's only certain games, or only some of the time, then make sure the controllers and memory card(s) are securely inserted, the game disc is clean, the laser lens that reads the disc is clean, and that the disc area is free of dust and dirt.
Sep 18, 2007 | Nintendo GameCube Console
Sony PlayStation 2 (PS2) Console Logo
24 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
