Question about Acer Aspire 5610-4648 Notebook
Where exactly do i put it?
Hey, i kinda figured that is the place for memory cards, but i'm not shure where to put it.i tried to place it in the lower left and then right corner...but i don't think it works, it doesn't show me anything on my hard.So any suggestions about the right place?
My cliq phone is not recognizing my sd memory card. But its in. What's happening and how do I fix it?
Maybe your memory card or the memory card slot has a problem. To figure that out, try placing another memory card to your phone and see if it works. If it doesn't, try to place your memory card to another phone and see if it works.
Hope this helps! -jayps
Mar 15, 2011 | Motorola Mobility CLIQ Cell Phone
Install motor mount 2000 grand prix
you loosen the nuts and jack the engine up from underneath place the new mount in position and slowly lower the engine down into place. it helps to have the tire removed and to have someone helping as the bolts on the mount will not want to go exactly back into place you have to kinda pry them over into the hole and get it lined up then lower the engine into place
Apr 05, 2010 | 2005 Pontiac Grand Prix
Coolpix L18 transfer
buy a memory card reader ... it will work
Mar 06, 2009 | Nikon COOLPIX L18 Digital Camera
Cant instal micro sd card to samsung E250
Hey! samsung SGH-E250 doesn't support 4GB memory card. Try a 2GB or 1GB memory card.
Jan 04, 2009 | O2 Samsung SGH-E250 Cellular Phone
Memory card
go to your menu section and disable the protection there.
Sep 08, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Memory card will not format
good question about card size-camera proably supports up to 2gb only-try someone elses card and if it goes in and works fine assume you have a bad card-if not stick to 1 or 2 gb only and use a good brand like sandisk or pny only
Jun 17, 2008 | Kodak EasyShare C663 Digital Camera
Memory card
hey there..what exactly do u mean by corrupted?....try formatting ur card....
Jun 05, 2008 | Nokia N72 Cellular Phone
Have a powershot sd550
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Feb 28, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
1 GB MICRO SD TRANS FLASH MEMORY CARD AND ADAPTER
hi,
what is the brand of ur flash memory card. some doesn't get recognized in OS lower than XP.. you might need a driver for it... knowing the brand would help.
regards.
bzoy
Jan 09, 2008 | SanDisk Memory Media
Memory card problems for sgh-e250
It seems hardware problem which can be solved easily but by the skilled technician. If u r not then will be better to approach to nearby technician as it is internal problem.
Jan 05, 2008 | Samsung SGH-E900 Cellular Phone
Acer Aspire 5610-4648 Notebook Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
