Ignites for 3 seconds then goes out - Heating & Cooling
    Genius:
  • 1,033 Answers
Check the flame sensor....this is a metal rod located on the opposite side of the Igniter. Uually cleaning it with steel wool will remove the oxidation that forms on the sensor and prevents the Furnace from completing the circuit.
Posted on Jan 06, 2013
Why is airbag light flashing?
According to the Nissan service manual the procedure to Reset the Air Bag System Warning Light is as follows:
1. Turn ignition switch from OFF to ON.
2. Air Bag warning light is on for 7 seconds and turns off, turn the ignition switch OFF within 1 second after the light goes out.
3. After ignition switch is turned OFF, wait for more than 3 seconds.
4. Repeat steps 1 to 3 twice. (Perform 3 times in total.)
5. Turn Ignition switch ON.
6. The SRS light should be reset.
If the warning light can not be reset I'd suggest you contact your Nissan dealer for more information and a proper diagnostics check as there be a fault with the airbag system.
Alan
Jul 10, 2014 | Nissan XTrail Cars & Trucks
How can I reset (oil reset unfinish ) message on Land Cruiser2010?
Land Cruiser
Reset the system by the following procedure:
1. Turn the ignition key to the "OFF" position with the odometer reading shown.
2. Turn the ignition key to the "ON" position while holding down the "ODO/TRIP" knob.
Hold down the knob until the light goes off. Before the light goes off, it illuminates for 3 seconds, flashes for 2 seconds, illuminates for 1 second.
Nov 03, 2013 | Toyota Land Cruiser Cars & Trucks
Lost key and alarm dodge caravan
to reprogram new key first you need to use 2 factory program keys.place first factory key in the ignition first turn ignition on for 3 seconds. then turn off ignition then install second factory in the ignition on position for 10 seconds.when immobilizer warning lamp begins to flash a acoustic signal is emitted.within 60 seconds. switch ignition off and remove key.then insert new key and switch on for 10 seconds a acoustic signal is emitted and immobilizer warning lamp remain illuminated for 3 seconds indicating programming completed.if all fails dealership has to reprogram new keys.
Dec 17, 2012 | 2000 Dodge Caravan
The burner ignites then goes out in about 10 seconds then it will re-ignite in about 3-4 minuites burn for about 10 seconds then goes out. I have replaced the coils and igniter. the thermal fuses tests...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 26, 2011 | Whirlpool LGR3624JQ Gas Dryer
Reset oil light
Toyota 4-Runner, Solara 2003-10
Turn the ignition key to the OFF position with the odometer reading shown. Turn the ignition key to the ON position while holding down the trip meter reset button. Hold down the button until the light goes off. Before the light goes off, it illuminates for 3 seconds, flashes for 2 seconds, and illuminates for 1 second. If the system fails to reset, the light will remain flashing.
Thank you for using fixya
Apr 10, 2010 | 2008 Toyota 4Runner
How do i turn of the timing belt light on my 04 landcruiser 3 litre
Ive never heard of a timing belt light, but there is a maintenance light that can be reset. Here the procedure:
To reset the maintenance reminder light: Turn the ignition switch to the "ON" position. Set the odometer/trip display to the odometer (ODO) mode. Turn the ignition switch off. Depress and hold the trip meter reset button while turning the ignition switch to the on position. The maintenance reminder light will, illuminate for 3 seconds, blink for 2 seconds, illuminate solid for 1 second and then turn off. Release the trip meter reset button. Turn the ignition switch to the off position. Turn the ignition switch to the on position. Confirm that the maintenance light goes out.
Let me know if this helped you out!
Mar 29, 2010 | 2004 Toyota Land Cruiser
2008 harley when l tun on ignition then press run the yellow malfunction light comes on for 4 seconds then goes out for 2-3 seconds then comes back on for 4 seconds then goes out and stays out even with...
this means you have a trouble code. please verify year of bike...if a 2008, perform a wow test to get the trouble code: to do this you have to hold in your speedo reset button and turn ignition on and it will show you the code. (ck owners manual for code breakdown)
Dec 26, 2009 | 2000 Harley Davidson FXSTB Night Train
Maintenance light on dash how do you reset it had oil changed but they did not reset the light
Courtesy of www.synthetic-direct.ca
  • Turn the ignition key to the OFF position with the odometer reading shown.
  • Turn the ignition key to the ON position while holding down the trip meter reset button.
  • Hold down the button until the light goes off.
  • Before the light goes off, it illuminates for 3 seconds, flashes for 2 seconds, and illuminates for 1 second. If the system fails to reset, the light will remain flashing
Hope this answers your question. Best of luck.
Greg
Jul 22, 2009 | 2004 Toyota 4Runner
Nissan Installed throttle reprogram
Here is the way to do it without the nissan scan tool. Make sure to follow all steps and it it best if you use a watch with a second hand.
1. Perform "Accelerator Pedal Released Position Learning".
a. Make sure that accelerator pedal is fully released.
b. Turn ignition switch 'ON' and wait at least 2 seconds.
c. Turn ignition switch 'OFF' wait at least 10 seconds.
d. Turn ignition switch 'ON' and wait at least 2 seconds.
e. Turn ignition switch 'OFF' wait at least 10 seconds.
2. Perform "Throttle Valve Closed Position Learning" .
b. Turn ignition switch 'ON'.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound. 3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic 'PREPARATION' (previously mentioned) are in good order.
5. Turn ignition switch 'OFF' and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch 'ON' and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal. 8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL goes off.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the specifications.
13. If idle speed and ignition timing are not within the specification, the result will be incomplete. In this case, more test needs to be done.
Jun 24, 2009 | 2004 Nissan Sentra
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
