Question about RCA L46WD250 46 in. LCD HDTV
Rca model 46la45rq with big vertical black line
Starts with a flickering red 2 in line, then about a 6 in black line with lines of color along its side, then it disappears,back to little red line
5 Suggested Answers
  • 1030 Answers
SOURCE: 52" RCA Projection TV
This is an indicates what is know as convergence problem...this could also be what is know as deflection problem... have a technician look at it.
Posted on Dec 07, 2007
premtech
  • 934 Answers
SOURCE: rca p56927 colors out of line
It's most likely a failure of the convergence amp and some other power supply problem in the convergence circuit by the sounds of it... Your unit takes an STK730-130 and some 750k 1/4w resistors for the yoke return. I would bet two or more of them are out of value, at least R19702 and R19703... There are also two diodes Cr19710 and Cr19709. P/N# 164590 which commonly open under a load and are recommended to replace anytime the convergence amp is replaced. Also check Q19700 (Bc457) which crosses nicely to an NTE123a...
Not real expensive in a reputable shop - just a pain this time of the year.. I would recommend getting it repaired, it's worth it..
Bill
Posted on Dec 19, 2007
SOURCE: vertical line on screen
It sounds like you have a bad cable coming off of your Plasma Screen that goes into one of the buffer boards or a bad buffer board (Hopefully the latter which is easily replaced but most likely not!) I have run into the same problem and there is an IC made into the cable that goes out and would be very difficult to repair if it is even possible.
Posted on Jan 26, 2008
SOURCE: RCA TV flickering problem
Help! I have an RCA 40 inch HDTV (Model# D40W20). I've had it since 2005. Recently, the picture will flicker when I turn it on, but will stop flickering after a few minutes. My brother has the 52 inch model and his tv did the same thing before it broke down completely. Does anyone know what the problem could be?
Posted on Jul 24, 2008
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
Red vertical lines samsung
Line faults & possible causes to LCD screen is given with illustrations.
Jul 29, 2014 | Samsung LN55C650 TV
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Left side of display has flickering vertical lines
Bad video driver chip for that location. Needs to be serviced.
Jan 14, 2014 | Samsung LN-S4051D 40 in. LCD Television
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
MAY HAVE BEEN HIT BY LIGHTNING. BLACK SCREEN AND 2 COLORED LINES
Replace the deflection board. Sounds like the vertical deflection was knocked out thats why you still have sound. You can get replacement deflection boards from www.tvrepairworld.com
Aug 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Getting a picture but double visioned and red lines running through it
This is 1 of 2 problems.
1; Convergence(depending on the model of the TV, the convergence ic's will have cold solder joints) 2: vertical ic issues.
If they are different colored lines & the picture also bends, it's a convergence problem. Else suspect a vertical problem. In the case of vertical issues, most of the time it's a defective capacitor (or cold solder joints.).
if it's the 3-crt kind of big screen, it's possible for one of the tubes to be going bad.
Feb 28, 2010 | Televison & Video
Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
Oct 28, 2008 | RCA L26WD26D 26 in. LCD TV
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
RCA L46WD250 46 in. LCD HDTV Logo
20 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
