Question about Kodak Esp 3.2 Wireless All-In-One Printer
Kodak 3.2 printer lcd screen wont turn on - Kodak Esp 3.2 Wireless All-In-One Printer
Cant print from camera to printer. camera works fine until i plug it in to the printer,then LCD screen wont come on, print options are on camera not on printer, both camera and printer have pictbridge
How about DPOF (digital print order format)? Usually that is configured prior to connecting to the printer. I have never owned or used a Kodak in my life but this is an option you can check.
Nov 03, 2015 | Kodak EasyShare Cameras
Camera works fine until i plug it into the printer, at that moment the LCD screen goes off and wont come on again so i can't print any pictures
Normally there is a kodak software you run on the PC and it show you the pics from the camera. Your trying to print directly to the printer without a PC? If so then you would use the printer menu.
UPDATE: Found the 310 user manual online from the Kodak site.
http://resources.kodak.com/support/shtml/en/manuals/urg00431/urg00431c3s3.shtml
Oct 22, 2015 | Kodak Cameras
Advent resetting ink levels
Hi There
Your all-in-one printer is designed to stop printing before quality is compromised. Make sure you always use KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to the KODAK Store.
To resolve the error, replace the black ink cartridge with a new cartridge:
  1. Turn on your printer.
  2. Open the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers, if the ink cartridges don't move to the center when you follow the instructions on the LCD screen, see Printhead and ink cartridges do not move to center with access door open.
  3. When the printhead stops moving, pinch the latch on the black ink cartridge and lift it out of the printhead.
  4. Remove the new black ink cartridge from its bag.
  5. Remove the protective cap from the black ink cartridge.
    CAUTION: Insert the ink cartridge immediately to prevent the printhead from drying out.
  6. Insert the black ink cartridge into the printhead.
  7. Press down on the tab until you hear a click.
  8. Close the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
If the error continues, upgrade the firmware for your printer:
  1. Press the Cancel button on your printer to clear the error message. (If the error does not clear, contact us.)
  2. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
  3. If the error continues, contact us.
Support Link :
Mar 29, 2012 | Office Equipment & Supplies
How do I replace the ink cartridge when it will not center when I lift the lid
Since you are not able to find the carriage ( which holds the cartridges ) in center position, Try to move the carriage manually to center. Make sure the printer is On or you can turn it off and move it to center and replace the cartridges.
Also, follow the steps given below as well.
  1. Remove the color ink cartridge.
    • Open the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
    • Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
      IMPORTANT: Make sure you are using KODAK Ink Cartridges. Your KODAK All-in-One Printer is designed to work with KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of either non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to Kodak's Web site, then to KODAK Store.
  2. Check the two electrical contacts on the ink cartridge for small marks, which should appear if the cartridge was installed correctly.
    If the electrical contacts do not have small marks:
    • Reinstall the ink cartridge, making sure you press down on it until it clicks into position.
    • Remove the color ink cartridge, then check the two electrical contacts on the ink cartridge again for small marks. Repeat if necessary.
    • Reinstall the ink cartridge.
  3. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
If the error condition continues, power cycle the printer:
  1. Turn off the printer.
  2. Disconnect the power cord from the back of the printer.
  3. Wait five seconds.
  4. Connect the power cord to the printer.
  5. Turn on the printer.
If the error is resolved, upgrade the firmware for your printer:
If the error continues,try contacting the Kodak Tech support by clicking on contact us.
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 26, 2010 | Kodak ESP5250 All-In-One InkJet Printer
My lcd screen is white?
I put my camera on a charger the screen turned white then it turned off and wont turn back on.
Feb 10, 2010 | Kodak EASYSHARE M763 Digital Camera
Hi... I have a Kodak EasyShare CD82 Digital
Sherry, have you tried to replace the battery of your camera? The recommended battery for your camera are the Ni-MH battery and the Alkaline battery. Now if you already using this type of battery and still your LCD screen is black its time for you to call Kodak at 1 800 235 6325 ext 12, it means that the LCD screen of the camera is already defective.
Feb 08, 2010 | Kodak Cameras
After downloading pictures to printer, turned on camera but screen just black. Will take pictures but everything just black.
If there is no light in the little light above the LCD.
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
If there is a light in the little lamp above the LCD.
You will need to order your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 19, 2009 | Kodak EasyShare C913 Digital Camera
Kodak esp 3 all in one printer home center wont work
hello,
Run the clear utility. Go to www.kodak.com/go/clear
Step by step instructions are provided in that website.
after that uninstall the AIO Home center.
In the Control Panel, select Add or Remove Programs (WINDOWS XP OS) or Program and Features (WINDOWS VISTA OS).
Choose KODAK All-in-One Printer Software
Click Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA
OS).
When the Install Wizard appears, click Next.
Select Remove from the drop-down menu for the Kodak All in One Printer, then click Next.
Click Next.
Click Continue.
Thanks
Neerak21
Sep 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak esp 7 paper jam
you will get a new only if the printer is within 30 days from the date of purchase so it is ok to have refurbished printer,,,,,,,just give them a headache when you have problem with this..........
Jun 05, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
LCD wont show the View and No picture
CCD failure most likely. Format the card then try again or a new card. Kodak customer support for more info
Jun 08, 2007 | Kodak EasyShare DX4530 Digital Camera
Open Questions:
See all Kodak Esp 3.2 Wireless All-In-One Printer Questions
Kodak Esp 3.2 Wireless All-In-One Printer Logo
49 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
