Question about Mitsubishi WD-57733 57" HDTV
White dots appear on screen
Started with one small white dot now tgeir are hundreds of small white dots on screan
  • Richard Stella Jan 24, 2013
    Mitsubishi was contacted about white dots appearing on screan they said that
    the DLP was defected and they had someone come out to replace it part was free even though the tv was out of warrantyservice charge would be $200. which was cheaper tha replacing the wp57735.
    New Friend:
Sounds like your DLP chi is faulty
Posted on Jan 06, 2013
SOURCE:
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Mar 07, 2013 | Televison & Video
Ecently a small dull black dot has started appearing on my canon power shot A630's lcd screen but when I review the pics taken prior to when I noticed this problem, no dot appears.
1) this is indicative the lcd camera has been faulty.
2) you must replace it.
3) contact your company supplier, and get the parts, you can do it yourself, only need small screwdrivers and common sense.
God bless you
Sep 17, 2012 | Canon PowerShot A630 Digital Camera
Small white dots have started to appear on our screen, first, on, then a couple days later 2 more, and today we have 6 small white dots on our screen. What is happening to cause this condition?
Your problem is that the DMD device is failing. You're in luck, though. Mitubishi has recently released a replacement DMD device in order to keep repair costs down for the consumer. Take your TV to an authorized Mitsubishi servicer for repairs.
Sep 25, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
A small white dot like spotlight appears on my laptop screen. how to make set it alright.. please do suggest me
Hi there, That Dot is a dead pixel on your Laptop Screen and it cannot be repaired except if you have the screen replaced.
regards,
Jul 28, 2011 | Computers & Internet
Three small white dots have appeared on the screen. What does it mean, is the lamp going bad?
White dots are caused by the DLP chip failing.This part must be replaced to get rid of the white dots. Samsung is covering the cost to repair this problem on several models. Ypu can call 1-800-samsung to find if your unit is covered.
Oct 06, 2010 | Samsung HLN617W 61" Rear Projection HDTV
White dot on my samsung DLP 42" screen
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
Jul 04, 2010 | Samsung Televison & Video
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
White dots appeare on my Samsung LCD screan
Sounds like your panel is on its last legs so to speak.
Might be time to look into replacing the panel. Running a high contrast can lead to a shorter panel life which may cause the occurence of dead pixels.
Mar 02, 2009 | Samsung LN-T4665F 46 in. LCD Television
Flickering dots
The symptom you described is called diffusion. A simple alignment, normally in the power supply takes care of this problem. For the nearest Authorized Service Center near you contact Toshiba online at: http://webmail.tacp.com/service/servcntr.nsf/$$Search?OpenForm Hope this helps
Jun 03, 2007 | Toshiba 42HPX84 42 in. HDTV-Ready Plasma...
Mitsubishi WD-57733 57" HDTV Logo
300 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
