Question about Bowflex TreadClimber TC5000
TREADCLIMBER tc5000 error code L5
Has power but not running. Error code L5 it says.
    Top Expert:
  • Bowflex Master
  • 12,223 Answers
Step 1:
see the comment. and fix it. Run the software calibration.
"SAFETY SHUTDOWN Loss of Speed Signal" or "L5" WITH NO belt movement
The speed sensor is not recognizing any motor movement. This displays the error message to the upper board. Refer to the proper flowchart.
Step 2:
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Posted on Jan 08, 2013
2 Suggested Answers
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Posted on May 30, 2009
What is l5 error
Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. If this error occurs with no belt movement, the causes for the LS or L5 error are:
A) Faulty upper display board or faulty relay board
B) Improper speed control wiring
C) Improper motor control wiring
D) Worn or faulty motor brushes
E) Faulty pwm/relay combo board or faulty drive motor
This error can also occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:
A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring
If you find yourself needing any further assistance please do not hesitate to call our technical support team at 888-713-2880 or check out our technical support center at http://www.sportsmith.net/supportsearch.aspx we would be more than happy to help!
Aug 03, 2015 | Exercise & Fitness
What is L5 mean
Hi dear.That should be LS Code instead of L5.Please check the followings.I hope that helps.Thanks.
LS
Lid Switch Error
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
Sep 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error E5 or L5???
L5 means it cannot sense the lid open or closed.
Lid switch is likely bad.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
What is L5 code on whirlpool calypso model #GVW9959KQ0?
Aug 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer stops working and the light flashes L5
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jun 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
I have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Dec 29, 2009 | York Exercise & Fitness
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
L5 flashing on my calypso washer
The error code is actually a LS not L5, it stands for a lid switch error, it could be a bad lid switch or you may have forgotten you had a previous load in and went to rewash and went and started the machine without opening the lid which automatically throws an LS error.so check the lid switch .hope helps p-ls appreciate by rating as fixyaa
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
KENMORE CALYPSO WASHING MACHINE
Jan 26, 2009 | Washing Machines
Bowflex TreadClimber TC5000 Logo
6,950 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
