My hard drive is not being recognize
My external hard drive memory, HITACHI 500 GB, IS NOT BEING RECOGNIZE BY MY LAPTOP OR TABLET. Can I fix this problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 137 Answers
You can not use the data recovery software as it only works in the operational devices. But you can give a try to make your hard drive detected. Read out the below article to make your hard drive visible.
Hope you will able to make hard drive visible by following the steps. But in case if not then you can search for the best and trusted data recovery services providers and obtain their service.
Posted on Apr 03, 2018
  • Computers & ... Master
  • 27,725 Answers
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Posted on Jan 07, 2013
SOURCE:
SOURCE: External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
Posted on May 13, 2008
SOURCE: XP doesn't recognize my external 500 GB WD My book essential edition hard drive
I had the same problem some have posted about. I had a lot of data on my drive and then one day it didn't show up in "My Computer" anymore. I had to assign a separate drive letter to the external drive.
Plug in the drive.
Right click on "My Computer"
Click on "Manage
Click on "Disk Management"
On the bottom half of the right side you should find "My Book" assigned to a disk number.
Right click on "My Book"
Click "Change Drive Letter and Paths"
Click Change
Select a new drive letter and hit OK
Hope this helps some people out.
Posted on Nov 06, 2008
bob_computer
  • 3153 Answers
SOURCE: Computer won't recognize hard drive and I have a lot of data
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
  • 355 Answers
SOURCE: samsung external hard drive not recognized
its happens when the hard drives cable or usb port is problem
change the ccable then try
other wise plug the pci usb card & first diseble the motherboards usb port
then try
ok bye..........................................
Posted on Nov 17, 2009
lock123
  • 6831 Answers
SOURCE: the Seagate Barracuda 7200.10 500 GB SATA Hard
Hello
OK, you need to let me know if the drive spins up, you should be able to hear it. Also, you need to have a listen if the drive makes a clicking noise.
Please be so kind tom let me know.
If the drive makes a clicking noise the drive is done, you will need to take it to a recovery institution to recover the data.
If the drive does not spin up, the circuit board or the power cable might be broken.
Hope this can be of help.
Kind regards
Andrea
Posted on Jun 17, 2010
Drivers windows 7-64 laptop needs drivers for hitachi hts545050b9a300 500 gb external drive
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Jan 14, 2013 | Hitachi (hts545050b9a300) 500 GB SATA Hard...
I Have a Hitachi Lifestudio hard drive attached to my Apple G5 for 7 months now, and suddenly just dessapear of my desktop or menu the Computer it won't recognize it anymore HELP!!!!!!
ry connecting the external hard drive to another computer to recover/backup your data.
When you have such a large capacity hard drive, it pays to have a second large capacity hard drive to backup your data in the event of the other hard drive dying.Hard drives do fail especially if you accidently drop it.
Jun 07, 2012 | Hitachi Lifestudio Desk Hlsdbub5001bbb 500...
Laptop is not detecting new Hitachi x500 external hard drive
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Aug 01, 2011 | Hitachi 500 GB USB 3.0 Portable External...
Wd 500gb hard drive is not shown any power it was working fine suddenly when i try to connect to my laptop nothing appearing. plz advice
Good day, this video tutorial will help you to recognize your WD 500GB. Just follow instruction and your problem will gonna fix.
Jul 30, 2011 | Western Digital My Book Essential 500GB...
Can my laptop sony vaio vgn-fj270 recognise a Hitachi Travelstar 500 GB Hard Drive? I tried everything and nothing work
Is it an external or an internal disk-drive?
What have you tried?
What error-messages did you get?
Nov 21, 2010 | Hitachi Deskstar 7K500 500 GB Hard Drive
Computer will not recognize one 500 external hard drive- nothing wrong with connections- other external hard drives are fine. I have tried everything
What OS are u working on? some old ones dont recognize this big hard drives, cant remmember the limit but it was around 300. Try updating ur OS if u are working on windows xp(get it to Service pack 3). I think this problem was fixed at sp2, but just to be sure.
Nov 02, 2009 | Western Digital 500GB My Book World...
New laptop wont recognize external hard drive files
What program was used to 'Back them Up"?
It may be an incompatibilty with Vista and you should contact the backup programes support arm to get a converted fix for Vista
Please rate our help to keep FREE service online
Aug 30, 2009 | Western Digital My Book Essential Edition...
Does not recognize
Did you try the disk on a different computer to make sure the disk is functioning?
And if using a laptop, make sure that power is not an issue, an external power supply or 2 USB ports are always required.
Also check:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Maybe one of those troubleshooting suggestions can help you.
Jules
Mar 16, 2009 | Western Digital External USB 2.0 80 GB...
May 11, 2008 | Western Digital My Book Home Edition 500...
Computers & Internet Logo
238 people viewed this question
Alun Cox
