Question about Danby DWC283BLS Wine Cooler
My door came loose on my danby wine fridge, how can I fix it?
The door handle is loose. How can I fix it without hurting the seal of the door?
computafixa
  • 317 Answers
SOURCE: danby silhouette wine fridge
sounds like there is a problem with the freon system. Either it is mis routed, or it is low on freon. Find a good refrigerator repair man, an ask him to heck if your system has sufficent freon, and if the system is functioning correctly.
Posted on Apr 14, 2008
SOURCE: Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
Posted on Jul 22, 2008
  • 3 Answers
SOURCE: wine fridge light does not turn off
You may know this already, but for what its worth. There is a small switch on the bottom vent grill for on/off of light. Check there first.....
Posted on Feb 01, 2009
  • 44 Answers
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Posted on Aug 21, 2009
  • 552 Answers
SOURCE: Danby dwc212bls-wine fridge stopped cooling after
you are exactly right you have a freon leak, a cfc technician will need to make the repair legally. let me know,
http://www.appliancerepairlesson.com/
Posted on Mar 07, 2011
Repair door gasket seal
try there for parts enter model http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC612BLP/3055/0169000?pathTaken=&prst=0&shdMod=DWC612BLP
Apr 27, 2014 | Transtherm Furniture
GASKET SEAL BAD
try at sears parts direct
Jan 13, 2014 | Danby DWC283BLS Wine Cooler
How do you mount the door handle on the summit swc530lbist?
Open the door on it. Gently pinch the seal and pull on it while giggling it and it will eventually come out to expose the Chanel with two holes that expose the screw heads. Simply tighten on the handle from the backside and push the seal back in place and your done.
Apr 15, 2012 | Summit Commercial Summit Professional Wine...
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
Recently, the wine fridge has started to make a whirrring sound that lasts around 4 or 5 seconds, then stops for around 20 or 30 seconds, then starts whirrrring again. Sounds a bit like a man moaning....
it was the internal fan in the upper rear section of the fridge. Apparently, since it is mounted so close to the rear panel, the sound seems to amplify from the back. Anyway, a replacement fan was only $3.71 direct from Danby, but I did have to pay 7.99 for shipping. Also, there is a fair amount of disassembly and re-assembly needed, which might be challenging for those who don't typically make their own repairs. Once removed, the only thing I could find wrong with our old fan was that the shaft was very loose in the unit, which may have indicated a bad bearing.
Canby may be reached at the following link:
http://danby.com/customer_service
May 21, 2011 | Danby DWC283BLS Wine Cooler
DANBY dbc657bls This is a beverage fridge by Danby Designer. I have 2 of these fridges and one is just starting to get ice build-up at the back. I have defrosted it a couple of time and the problem of...
you have a door seal leak, the ice is from outside air getting into the cooler, you might also check for an air leak it the service door in the bottom back of the cooler.
Jan 21, 2011 | Danby DWC610BL Wine Cooler
Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 15, 2008 | Danby DWC283BLS Wine Cooler
Wine fridge light does not turn off
Nov 27, 2008 | Danby Silhouette DWC512BL Wine Cooler
How do I fix loose handle?
havnt worked on that but... most times theres a cap or piece that will come off hiding the screw not sure what yours is cant find anything on it .. hope that may help some
Sep 02, 2007 | GE Monogram ZDWC240NBS Stainless Steel...
Danby DWC283BLS Wine Cooler Logo
Top Danby Furniture Experts
Dan Webster
Dan Webster
Dennis Boxerman
jdthefixer
Are you a Danby Furniture Expert? Answer questions, earn points and help others
