Question about Compaq Presario Notebook
Wireless card disconnected
How do I enable wi-fi abilites?
    Novelist:
  • 176 Answers
Theres a switch on the side or upfront to turn it on. after that you'll see a little icon on your lower right task bar where you can right click it to "view available wireless"
Posted on Jan 20, 2009
DELL Latitude E6510, wifi button was OFF, now it is not working.Wifi is showing red cross. Please help how t0 turn it ON? I think it is Hardware issue. Can I fix it through Windows? Windows 7
Information Technologies
Share
Enable / Disable an Enterprise Laptop's Wi-Fi
Wi-Fi, short for Wireless Fidelity, is networking technology that allows you to connect to the Internet. If you have a wireless-enabled Latitude computer you can connect to the Internet when in range of an access point called a hotspot.
When not in use your Latitude's wireless card should be disabled. By disabling Wi-Fi, you will receive two benefits:
Start-up times will be much faster.
If the wireless card is ON and you are out of the office (not connected to your normal, wired connection), the laptop will try to use the Wi-Fi network during the login process to run the various start-up scripts, etc. It will eventually time-out (fail). By having the wireless card turned OFF, the start-up process will be much faster.
Computer will not continually search for a wireless network (and waste battery life).
If you are in the office (connected to your normal, wired connection) or in a location where there is no wireless hotspot, you don't need to have the computer waste processing power by looking and looking for a wireless hotspot. By disabling Wi-Fi, you will gain a little more power for your other tasks. In addition, you will maximize your battery operating time by disabling wireless activity.
NOTE: After your Latitude has started up completely, you can ENABLE the wireless card and connect to a wireless hotspot. For example, a wireless router at your home or at a local coffee shop. If you have connected to this hotspot previously, the wireless card should connect automatically for you.
NOTE: Once you have the wireless card enabled, before you shut down the computer, you should again DISABLE the card. The computer will then be ready for the next time you turn it on with wireless turned off.
Enable / Disable with Hardware Switch
The more recent Latitude models have a wireless switch to enable or disable wireless network devices and the
Wi-Fi Catcher Network Locator.
Dell Latitude E6420 and E6520 Series
These laptops have a small switch on the RIGHT side of the keyboard. The switch is toward the front of the laptop. The Wi-Fi Catcher™ icon will is above the keyboard. You will see a lit radio tower if the wireless switch is enable
Oct 17, 2016 | Dell Latitude E6510 Notebook
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
Wlan card disabled
The Dell Latitude E6400 laptop comes with an Intel Core 2 Duo processor for fast computing and an NVIDIA graphics card for video playback, gaming and Web browsing. The laptop has a built in Wi-Fi card, letting you connect to the Internet on-the-go. However, if you're unfamiliar with Dell or the laptop's factory installed Windows Vista operating system, you might not know how to enable to Wi-Fi.
Slide the switch on the side of the laptop toward the front of the laptop. This switch enables Wi-Fi connectivity on the Dell Latitude E6400. When switched into the back position, the Wi-Fi is turned off. Turn on your Dell Latitude E6400 laptop and log into Windows Vista. Click on the Windows "Start" button. Click on "Wireless," located in the Start menu's "Show" list. A list of currently broadcasting wireless networks appears on screen. With your Wi-Fi enabled, you can connect to any of these available networks. Secured networks ask you for a password when you click "Connect," while unsecured networks connect automatically.
Feb 03, 2013 | Dell Latitude E6400 Notebook
No wireless working
enable it from the bios ,,, enable it pressing the wi-fi key ,,, replace the wireless card or switch the antenna cables connected to the wi-fi card ...
it would be much better if specified a model ,,,
Mar 06, 2012 | HP Pavilion 1137NR Notebook
Issue with HIRO H50069 running on XP 32-bit. Network card keeps randomly disconnecting and reconnecting to wireless networks.
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Hiro (H50069) Wireless Adapter
My msi mini note pad will can up to the internet when plugged directley in to the modem but not via wireless router, how do i enable the the laptop to pick up the wireless signal
First make sure wi fi switch on laptop is turned on.
MAke sure wi fi network adapter driver installed and enable.
Right click on my network places so you can see your wi fi network adapter there if it is installed .
Right click on it then enable.
Then again right click on it then click on view for available wi fi networks.
Then it find network if any wi fi router is in range.
Then click on connect.
Thanks.
Nov 04, 2009 | MSI Graphics Card - ATi RADEON 9550 250MHz...
Hardware manager shows the device as working correctly but cannot locate any wireless network. Is this a PCI card or internal? Known good wireless routerr right next to the notebook
First check your wi fi network drivers are installd and enabled .
Then turn on wi fi switch on laptop.
then also check on your router wireless is enabled.
then check.
Aug 21, 2009 | Computers & Internet
Just got bt wireless broadband but computer will not conect via wireless. computer only 4 years old thought it would have had wireless mode built in??
First check in your router your wireless option WI-FI is enabled.
Then check in laptop Wi fi driver are instaler and working properly.
Also make sure your wi fi is enabled in network plces property and wi fi switch on laptop is turned on in laptop.
Aug 07, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Can my 1625CDT be made WI-FI adaptable
Any laptop computer that doesn't have a built-in wireless card can be wireless enabled by installing a PCMCIA wireless card or an USB wireless adapter. Go and see your friendly computer shop.
Aug 06, 2009 | Toshiba Computers & Internet
I have an HP Pavillion DV4000. My built in wireless is not working. The light at the top of the keyboard does not come on. How do I get it to work?
you can see the wi-fi switch...you turn on and it will work if you install already the wireless driver...its only the problem with the switch combination between wireless..there some option also for enabling the wi-fi...you can press FN key + wi-fi botton.
Jan 28, 2009 | HP 14.1 Refurbished Thinkpad, 1.13GHz...
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
