Question about Dell XPS M1530 Laptop
On y xps m1210 i cannot get the volume working
At all it is saying the speakers are fully up but still no sound i think this may have something to do with the screen saver
    New Friend:
  • 4 Answers
There could be a couple things that could be wrong. i dont see how a screen saver could have anything to do with it but with both xps models m1210 and 1530 they have a common problem that could cause this to happen that being the geforce 8 series chip witch can cause many symptoms including wifi problems and sound problems, now if this is the issue i would back up your files while you can because what happens is the chip over heats and detaches itself from the board and the system will not work at all, the only thing that will happen at this point is it will tern on and the screen will stay black.
If that is not the issue than theres still a couple things it could be i would just need more info to troubleshoot, or you could take it to a local shop and they could do the work for you because something like this could entail checking the hard drive for damage or replacing hardware witch is best handled by a professional.
Posted on Jan 16, 2013
T-Mania
  • 42 Answers
SOURCE: Dell XPS M1210 Administrator password and password log on problem
This is a known vista issue where it creates a backup of your profile for some reason there registry edits to try and fix it but a system restore is much easier. Follow the below steps to solve problem.
Turned computer on and immediately pressed F8 repeatedly until I got "Advanced Boot Options" select "Safe Mode" computer then opens safe mode login as admin if possible, with a "Help" window, in the help window there is an underlined "What is System Restore?" then select "Click to open System Restore" restore to a previous state before which the fault occurred.
Click OK and after config changes should be good to go.
Posted on Mar 19, 2009
INTERLOGIC
  • 326 Answers
SOURCE: Speakers not working after geek squad installed new hard drive.
check the corresponding drivers
Posted on Apr 19, 2009
trekkiekid
  • 10 Answers
SOURCE: Dell Xps M1210 Web Cam Driver missing
Mail the maker or costomer assistance and pleas send me more info at Trekkiekid@yahoo.com
Posted on May 21, 2009
kalra7
  • 16 Answers
SOURCE: my dell xps m1210 quickcam is not working
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R142311&SystemID=XPS_M1210&servicetag=&os=WW1&osl=en&deviceid=11933&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=189924
and http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R151795&SystemID=XPS_M1210&servicetag=&os=WW1&osl=en&deviceid=11933&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=17&fileid=202014
use both the links just copy and paste them in your browsers address bar and download and anstall the driver for your logitech quick cam
i hope it works for you
thanks
Posted on Jun 01, 2009
byteguy
  • 2229 Answers
SOURCE: Dell XPS M1210 broken
I'm thinking you might be having a hard drive problem or the file structure is really messed up.
You had Win 7 and tried to install Win XP. Now it is confused, no doubt.
Here's the first thing I would do:
Put in your Win XP disk and boot from it.
At the first question it asks (about repair or install) choose repair.
It will then ask you which Windows Installation--choose #1 if it's there.
Hit enter if it asks for your password.
Now at the command prompt, type chkdsk /?
Depending on your version of XP, it will show you the switches you can use. Use the one that checks the entire drive. Might be chkdsk /P or maybe /F
Anyway, use the one that does the whole drive and let it run. Then try your reinstall unless you have file problems that aren't fixed.
BTW--your Dell should have a utilities option if you hit F12 at startup that will allow you to check your hard drive.
Posted on Oct 26, 2009
Dell XPS M1210 Stuck on blue screen due to hard drive
To determine if your hard drive is bad or good, run the Dell diagnostics.
Here is a link for the owner's manual of your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_xps_laptop/xps-m1210_owner%27s%20manual_en-us.pdf
Feb 08, 2013 | Dell XPS M1210 Notebook
I have a dell xps M1210, and It has problems with the screen. I already probe and it work fine with an external monitor. You can not see the images well but there is not problem with text. I think there is...
hello, if works fine whit external monitor so is no problem whit motherboard, problem must be in display or the connector that connect motherboard to display
its not dificult to change display but i recomand that u go to a specialist
Sep 23, 2011 | Dell XPS M1210 Notebook
Delete, end and insert key do not work doyou have a keyboard for an XPS M1210 notebook?
Here are a few links: <div><a href="http://www.discountelectronics.com/index.php?l=product_detail&amp;p=2281">http://www.discountelectronics.com/index.php?l=product_detail&amp;p=2281</a></div> <div><a href="http://www.amazon.com/Laptop-Keyboard-M1210-NG734-Notebook/dp/B001MW3U16">http://www.amazon.com/Laptop-Keyboard-M1210-NG734-Notebook/dp/B001MW3U16</a></div> <div><a href="http://www.machinaelectronics.com/store/keyboardkeys/Dell_XPS_M1210">http://www.machinaelectronics.com/store/keyboardkeys/Dell_XPS_M1210</a></div> <div><a href="http://www.laptopz.com/dell-m1210-laptop-keyboard-p-17187.html">http://www.laptopz.com/dell-m1210-laptop-keyboard-p-17187.html</a></div> <div><a href="http://www.cellularfactory.com/laptop/DELL/3/224286/">http://www.cellularfactory.com/laptop/DELL/3/224286/</a></div> <div><br /></div> <div>If you need further assistance please leave a comment.</div> <div>Cheers</div>
Aug 25, 2010 | Dell InspironTM XPS M1210 Notebook
Hercules XPS 210 sub problem. distorted sound
I think you've just answered your own question. It sounds as if you've coned the sub woofer. Meaning you've fractured the bond between the edge of the speaker body with the speaker cone. Or overheated the voice coil and it's distorted and not getting free movement. Excuse the Pun but it "sounds" like you need a new speaker as a replacement. If it's a particularly expensive speaker it can be reconed. A check of the Net for someone close to you will find a company who recones them. If it's a cheaper one then a replacement would be in order.
Apr 21, 2010 | Audio Players & Recorders
I have a Dell XPS M1210 laptop for which I have just purchased a new 9-cell compatible battery. It worked great for a couple of hours, but now shuts off immediately when unplugged from the AC power supply....
You might want to try what I did when I had a completely discharged battery for my Dell Laptop. I attached the battery to the computer, make sure the computer is off and plug in the charger for a full twenty four hours (undisturbed). And this really worked. I had no problems with the battery. Good luck.
Feb 26, 2010 | Dell XPS M1210 Notebook
May 21, 2009 | Dell XPS M1210 Notebook
I have Dell XPS M1210 notebook. By some accident its Front bezzel and Bezzel back side gets cracked. But LCD screen is fine. and notebook works very well. So i wanted Front bezzel and Bezzel back side.
you should call dell technical support they will help you with this, i think if you have complete care you can get a replacement for sure.
Further Queries are welcome
Feb 18, 2009 | Dell InspironTM XPS M1210 Notebook
Dell XPS M1530 Laptop Logo
Alun Cox
