Question about Mantis 2-Cycle Tiller
Vapor lock on Mantis
No gas in primer bulb
    Sergeant:
  • 322 Answers
Check the fuel lines for a breakage or the primer bulb for a crack. Sounds like it is sucking air instead of fuel
Posted on Jan 17, 2013
5 Suggested Answers
  • 3 Answers
SOURCE: Mantis tiller no fuel getting through to the
the fuel line may be clogged or is collapsed go to a car or a home improvement store go to lawn and garden and get a 3-4 mm gas line
Posted on Apr 23, 2009
  • 179 Answers
SOURCE: mantis tiller will not start
did it also run out of oil, because it seized like it did you might of burnt the engine
Posted on May 31, 2009
riceski
  • 1851 Answers
SOURCE: how can i get my mantis to start?
Hi again,
the I / o switch is for i = ignition or ON - the O = off
not seeing the choke you will need to push the control one way or the other - using memory push the choke control full one way and try to start the unit - it if fires off pull it back about 1 quarter of the way back away from full on choke.
As for pushing the bulb - if the unit has not been started for a month or more - push the bulb 10 times. - if you're restarting the unit after a short pause in use then 3 times.
Best of luck with this.
Also you might just want to drop by a Lowes hardware and they will help you if you need further help.
Thanks for choosing Fix Ya
Posted on Jun 07, 2010
Testimonial: "thanks for your help"
  • 17 Answers
SOURCE: Mantis tiller will not start.
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
Posted on May 24, 2011
Just bought a carb kit. Which way does the diaphragm go in ? Also,the primer bulb won't show gas.
if the primer bulb cannot pick up fuel and the fuel lines are good then you have a bad primer plate and you need a new carb
Mar 25, 2015 | Mantis 2-Cycle Tiller
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
No gas goes in the little rubber primer bulb
either a passage is blocked in carb or you bulb has a hole in it,is there any sign of gas near the bulb (leakage),if not I would most likely remove carb and soak spray out and reassemble.
Apr 23, 2010 | Mantis Tiller
Vapor lock
The tank vent is a bronze plug inserted into the tank casting--the caps are not intended to vent. Check the fuel filter for plugging and the condition of the fuel lines and primer bulb. You should be able to fill the bulb with fuel after several pushes of the primer bulb. Have the fuel lines been changed? Hope this helps!
Apr 12, 2010 | Poulan Pro Chain Saw 46cc 20"
After it starts its over heating cause vapor lock?
You do not need to press the primer if the machine has been running, over heating is another issue, the boiling sound could be the gas just super evaporating when it hits that hot cylinder, if its getting that hot there is some other issue. Maybe your fuel mixture is to rich, check to see that your fuel to oil ratio is correct.
Oct 05, 2009 | Garden
PRIMER GAS BUBBLE CRACKED & LEAKING
Carefully unsrew the two screws in the plate holding the primer bulb down and just remove it while holding the rest of the carb down. Take the bulb to a parts/repair shop and buy another bulb for a Zama carb and reinstall.
Jul 29, 2009 | Mantis 7225-00-02 2 Cycle Gas Power...
Mantis tiller won't start,does not seem to be getting any fuel in
if the primer bulb isn't filling up with gas when you push it the the diphram in the carb. behind bulb is bad needs to be replaced then it should work unless fuel lines are crossed or has holes in them
Jun 08, 2009 | Mantis Tiller
May 31, 2009 | Mantis Tiller
Mantis tiller no fuel getting through to the primer bulb
Apr 23, 2009 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Mantis 2-Cycle Tiller Logo
153 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
