Question about Frigidaire 18" Built-In Dishwasher
WHERE is the float switch on a frigidaire dishwater model # fmb330rgso
Dishwasher motor running but no water entering. dishwasher empty of water
  • Frigidaire Master
  • 3,247 Answers
I am not aware of any float switch in this model. If this a portable dishwasher and assuming the water inlet connection is open, it is likely the water inlet solenoid could be faulty. Check this site for location of parts.
Posted on Jan 06, 2013
SOURCE: Frigidaire dishwasher does not clean
the start switch in the motor is probably bad,it could also be the motor relay.if you can get to the motor run the unit and while it hums try to turn the motor.it also could be something is stuck in the motor let me know.
Posted on Aug 14, 2007
ngfam1
  • 639 Answers
SOURCE: Frigidaire 24" FDB1050REB2 Dishwasher It will
Friend,
ngfam1 At your service!
You plain old need service ! I am not hands on from this side of the wire!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New applinces are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
  • 3 Answers
SOURCE: Frigidaire Quietclean I "Not filling with water"
Sounds like you might have forgotten to turn the water on to the dish washer... it happens all the time
Posted on Oct 29, 2008
localwonder
  • 6784 Answers
SOURCE: Frigidaire dishwasher model FDB857RJS1 not pumping
HI, under the sump housing, there is a major issue concerning the circulation motor. there is a wash impeller that is connected to the circulation motor, via drive shaft and stud. this assembly has been stripped, due to a possible jam that was caused by a foreign object. the impeller is basically, producing the grinding sound you are hearing, you will need to replace this damaged wash impeller asap. it will ruin the motor soon if it is not removed.
This wash impeller is responsible for the flow of water during the wash cycle. it is not completely off the shaft but, eventually , it will break off soon, causing major damage to the circulation motor.
Posted on Jun 18, 2009
  • 10865 Answers
SOURCE: Dishwasher always fills to float valve
There are actually several possible causes of your problem. I will briefly describe each in hopes that you can isolate the problem and will then know how to proceed.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Aug 02, 2009
Wan't take on water after first rinse
see this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 30, 2013 | Whirlpool 24 in. DU1055XTPS Stainless...
Mine DU1055XTSS3 is not taking on water after initial rinse.
test this steps and fix it. GOd bless you
Water Inlet Valve
Float
Float Switch
Jul 30, 2013 | Dishwashers
Frigidaire model # GLD 2250 RD 85. Won't fill with water
see this causes and fix it. God bless you
If there's no water entering your dishwasher, check these:Water-inlet valveFloat switchWater-inlet valveThe water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.Float switchThe float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. To determine if the float switch has failed, watch the part testing video at the bottom of this page.9_25_2012_6_40_24_am.jpg
Sep 24, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
My dishwasher is overflowing water and will not drain
Most likely the float switch is hung up or failed. Here is a link that should help Dishwasher float switch Enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions.
Oct 07, 2010 | Frigidaire Dishwashers
No water entering dishwasher; motor running
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at http://appliancehelponline.com/dishfloatwaterinletvideo.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Jun 08, 2010 | Danby DDW1805W Designer Series...
Dishwasher - no water coming into it
If there is no water coming in the machine check first the water supply has not a tap and this is closing.
If water is supplied regularly, then the problem is either with the inlet valve or the float switch.
See the following indications from repairclinic:
" Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it."
Aug 29, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Frigidaire 18" Built-In Dishwasher Logo
151 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
