Question about Ovens
The heater will not stay lit, it burns for a few min. And than kicks off
    Genius:
  • Ovens Master
  • 1,669 Answers
If your connectors are clogged or dirty that might stop the flow of gas, or the gas tank pressure is too low. Also, if you do not hold the igniter long enough its tip will not get hot enough to keep the flame lit.
Posted on Jan 24, 2013
  • CJ Gonzales Jan 26, 2013
    Thank you I think it must be diet it's been cleaned twice now it's burning steady thank god it's been in the teens, thank you !
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Put in new valve and thermal couple but pilot stays lit , but when thermostat is turned on everything blows out after a few minutes
Check your exhaust does the flame on the burner look like it is starting to float after a few minutes if so you are starving for secondary air
Feb 01, 2014 | Bakers Pride Y-600 Gas Single Oven
I am using an old white westinghouse electric oven to bake a cake. I selected the right temperature which was between 150 and 160 cel. It started but I could hear the sound of a fan. I kept it on for at...
Either the temperature sensor has a problem (shorted so the control thinks the oven is colder than the actual temp) or a relay feeding the bake or broil element is welded shut and causing one of the elements to stay on. If the elements are still heating when the "ON" indicator is NOT lit, then you have a welded relay. You need the control board repaired.
Jun 25, 2010 | Philips Ovens
My Lincoln Impinger 1450 Gas conveyor oven may be having a thermostat problem. I have a double decker and it is only happening on the more-used one. The top oven has trouble maintaing heat. It will heat to...
is your blower working? if the blower is working it sounds like the sensor may be going out(or Out)! which is bascally the safety so the unit does not burn all other components up thats why it is needing to cool down to restart. check your fuses first make sure none of them are blown and only replace with the recommended size not just what is in there. Then work it from there you can hear the blower kick on and off like a torpedo heater on construction sites or like what you might have in a garage.
Mar 17, 2010 | Ovens
The bottom "coil" unit in my jenn air over w132 lit up like a firecracker and burned all the way around - and now doesn't work. I replaced it about 2 years ago for the same issue. Is there something bigger...
There are no official problem notices about this so basically no. I have customers that regularly blow heating elements and coils in many other brands and quite a few go every few months.
Nov 07, 2009 | Jenn-Air Ovens
Igniter stays lit entire time oven is on Blodgett dfg 100-1
I have seen this happen when a hole develops near where the ignitor is mounted. The excess gass overheats the ignitor and burns it up. What I do in a case like that is slide a c clamp over the burner and cover the hole.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 12, 2009 | Blodgett DFG-100 Gas Single Oven
Kenmore Gas Oven not working
IT POSSIBLY DOES IF SO IT WOULD BE UNDER TH BOTTOM PAN USUALLY IN THE BOTTOM OF THE OVEN , YOU WILL NEED TO LIGHT IT WITH A MATCH (AFIREPLACE MATCH WORKS BEST ) LET BURN FOR A FEW MINUTES TO MAKE SURE IT GOING TO STAY LIT BEFORE YOU TRY THE OVEN .
Nov 26, 2008 | Ovens
Won't stay lit/hot
call 1800hobart,they are a national chain.
Jul 17, 2008 | Ovens
Oven preheats then cuts off 70 % of the time
have you checked that your timer is set correctly
Jun 14, 2008 | Ovens
Ovens Logo
75 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
