Question about Bosch Washing Machines
I have a 300 Series Bosch front load washing machine witn an E:27 error message. I can't get it to reset. What is wrong?
In the middle of a load of laundry the machine stopped and an E:27 error message was displayed. I tried to unplug to reset but have not been able to. Any suggestions?
    Sergeant:
  • 291 Answers
Do you know what the E:27 error code means? Different machines have different codes. I am not a bosch expert, but if you provide the complete model # to your machine chances are good that i can find the meaning of that error code and maybe a whole lot more.
Posted on Jan 06, 2013
  • Mike Kraft Jan 07, 2013
    The model # is WFVC6450UC/25 for Bosch Vison 500 series washing machine.
  • B.H. Countryman Jan 07, 2013
    Look here: http://baubilt.com/?p=1318
5 Suggested Answers
  • 228 Answers
SOURCE: Hello! My Bosch Nexxt series 300 washing machine
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Posted on Aug 05, 2009
57 varieties
  • 1653 Answers
SOURCE: My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Posted on Oct 02, 2009
SOURCE: I have a Whirlpool front loading washing machine
The F-21 code is a blocked drain tube. Take off the front lower panel and locate the drain. Should be front right, Disconnect it and clean out the little trap that collects stuff. Put back together and should be fine. I always find stuff like coins and tissues wadded in there. It made for collecting foreign matter to keep the drain clear.
Posted on Jan 20, 2011
  • 6277 Answers
SOURCE: error code 04 is displayed
Bosch 'F04' is a problem with draining.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly.
Thanks and good luck!
John C
Posted on Apr 09, 2011
How do I fix an error code?
The problem it's reporting is a door latch fault. It may be a faulty latch, or you MAY just be able to clear it if it was a hiccup. Try the following six steps to clear the code, then see what hppens:
·Turn the appliance knob to the off or reset position, 12 o'clock.
·Turn the knob to the 6 o'clock position.
·Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position (One click clockwise).
Continue holding the spin button for about 5 seconds
·Release the spin button
·Immediately turn the knob to off
When your turn it back on it should have cleared the error code
Dec 24, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
Noisy pump on bosch 300 series washer
This video will show you how to clean the pump and how to find the fault on a washing machine that won't drain or empty the water away on Bosch, Neff or Siemens. Please remember to subscribe to our YouTube channel for all appliance tutorials
a thumbs rating is appreciated for answering your free question.
Aug 19, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Is there a way to reset the computer my bosch 300 nexxt series washer?
turn off THE POWER by c. breaker, wait by 45 seconds, and turn ON again and try it.
God bless you
Jul 10, 2013 | Bosch Nexxt 300 Series WFMC2201UC
Is there a reset button on a bosch 300 series washing machine
turn off the power to the unit for 45 min, that resets it
Dec 05, 2012 | Bosch Nexxt 300 Series WFMC2201UC
E-27 blinking
The E27 code isn't often listed in Bosch manuals but relates to the washer door lock.
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You may need to replace the door lock assembly on the washer.
Jul 20, 2011 | Bosch WFVC6450UC Front Load Stacked Washer...
I have a bosch nexxt 300 series washing machine. The problem is it had beeped code E04 the hoses were somewhat dirty and i cleaned those,but now the pump doesnt seem to be running and its getting hot. ...
bosch nexxt 300 series washing machine This video will show you how to change the pump washing machine
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 31, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing Machines Logo
437 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
