Question about Samsung LN52A850 52 in. LCD HDTV
Right side picture has vertical lines
Colored stripes. On right side of picture
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 158 Answers
Your screen is defective. The T-con board is working because its able to give you video.
Posted on Aug 21, 2015
lukster
  • 217 Answers
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Posted on Aug 03, 2008
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Posted on Aug 19, 2009
SOURCE: Samsung LN52A550 lcd tv has
I have a similar problem. I have vertical colored lines in the middle and right side of the screen is black. Here is the photo. Do you guys think it is the T-con board?_853.jpg
Posted on Mar 02, 2011
  • 8457 Answers
SOURCE: My Samsung LN52A550 has colored vertical lines in
Yes,this problems alway the problems and the causes by the T-CON decodering board.If this problems acurring by it self.If this problems are causes by and an object or a person by hitting the LCD screen panel itself,than LCD screen is dead,not repairable.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
  • 718 Answers
SOURCE: My Samsung LN52A550 has vertical
This most likely a problem with the T-CON board.
If this set is under warranty you should return it to get it repaired/replaced by the seller.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(board replacement ) or have a friend with knowledge/skill you can fix it.
Sometimes due to heating/cooling or contamination the connection pins on the T-CON board and cables do not make good contacts. The T-CON board is located in the center of the set.
After taking off the back cover and shield over the T-CON board carefully remove the flat cables connected to the T-CON board. I believe there are 4. The connectors have a lip on them to hold the cables so be careful.
Now reconnect the cables. Recheck the display now. If it has not corrected you can disconnect and reconnect again.
The very first solution I entered on fixya.com had essentially this same problem and solution.
If this does not solve the problem you can replace the T-CON board.
The T-CON board look something like;
Posted on Mar 04, 2011
Thin vertical colored lines 6''with on letf and right side of tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 23, 2015 | Televison & Video
Pioneer PDP-4300 43" Plasma TV, 1/8 of screen has vertical stripes no picture
Look to see PIP or picture in picture is not engaged as it may be doing this.
Dec 10, 2012 | Pioneer PureVision PDP-4300 43 in. Plasma...
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Samsung LN52A850 52 in. LCD HDTV Logo
91 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
