Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a 35 year old Sears garage door opener.
When I press the button it goes about 3/4 the way up and then reverses itself and goes back down
Also most of the time it will not work unless you take the electric power chord out of the socket then plug it back in, then it will work
    Champion:
  • 244 Answers
Buy a new unit. this old unit is not safe and therefore parts will no be available.
Posted on Jan 22, 2009
Hi, My 10 years old plus Craftsmen garage door opener will open OK from any of the buttons, but will only go all the way down when I press and hold the wired button by the door. If I hit the button by the...
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the small light on each sensor is not flickering ever so slightly. Tweak them a bit.
May 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have sears opener #139.53989. Every once in a while I have a down problem. It goes down within an inch of the floor and reverses. Sometimes I can hold the wired remote button and it will go all the way...
If the main light flashes 10 times when the door reverses it is a sensor problem. Check them very closely. If they are just a little off one of them will be flickering but it is difficult to see. This can also cause the problem to be intermittent. Tweak them just a little.
It is normal for that light to blink randomly.
Jan 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door goes up when I press the button, but not down
If when you close the door the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Check to make sure the small light on each sensor is lit and not flashing. They must be pointed at one another to work properly.
Jul 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door bucks like a bronco
You have a door problem. The reason the door is reversing to the open position is because when it bucks the safety senses something wrong. Release the door from the opener and operate it by hand. You should find something.
Jun 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a sears craftmen garage door and the control switch on the wall light keeps flashing and I need to know how to get it toa solid light and when I press the button to close the door it goes few...
When the door reverses to the open position and the main light flashes 10 times it is a door sensor problem. Usually the sensors get bumped and need to be tweaked so that they are once again pointed at one another. Each sensor has a small light that must be on for them to work. The light on one sensor stays lit all the time and the other sensor light is only on when they are pointed at one another.
The flashing light in your wall control is a separate problem. One of the buttons on the wall control has an icon of a lock. Press and hold it for 3 seconds and release. It should stop flashing.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
The door reverses back to open position instead of closing
SOUNDS LIKE A SENSITIVITY ISSUE UNHOOK THE DOOR AND TRY IT MANUALLY TO BE SURE IT DOESN'T BIND OR IS TOO HARD TO OPEN OR CLOSE.
IF ALL IS WELL CHECK THE SENSITIVITY SETTINGS ON THE BACK OR SIDE OF THE OPENER.
YOU WANT THIS SET AS LOW AS POSSIBLE AND STILL OPERATE THE DOOR WITHOUT REVERSING.
NOTE: THE FULL RANGE OF ADJUSTMENT IS ONLY ABOUT 3/4 TURN SO MAKE A VERY SLIGHT ADJUSTMENT AND THEN TRY IT AGAIN.
HOPE THIS HELPS
Feb 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener problems
We had the same problem.  open the unit and checkt the connections.  we had a few loose wires and every time there was a vibration whether a low flying plane or a truck nearby the door went up.  My husband found a few of the wires had loosened up.
Jan 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
