Question about Wowee One Slim Portable Speaker for iPad, iPhone Mp3 WOW-00019
My wowee one will not charge. have been charging it but no lights on. battery appears to still be flat
I have tried charging it on my mac too but still not working
  • vicky greenley Jan 06, 2013
    can anyone help? thx
My Audio headset has worked great-but now...it stopped working
Could be the battery has a weak charge! Try running the battery completely flat, recharge fully, then run completely flat, and repeat this cycle about 3 times......This will give the rechargeable battery a revitalised full charge! This is a good procedure for any rechargeable battery as part charging and charging when not completely flat does take its toll on a battery.
Nov 12, 2015 | AUVIO Bluetooth Headphones
My phone was unused for a day and the battery went totally flat. I charge the battery but there is no yellow light on the phone. The yellow light always appear when I charge the phone.
pull the battery out and reinstall to reset, charge again, could take a few mins to get charge light maybe need to replace battery with new one ??
Jan 01, 2011 | HTC HD2 Smartphone
When I am charging the mac book the orange light is turning to green then orange again.. why is it like that? how can I repair it?
This may indicate that your battery is going bad and not holding a charge. Try inserting a different battery and see if the light stays green.
Jul 12, 2010 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
The alernator does not appear to be charging the battery,the car has not been used for three weeks,battery has been charged but battery light stays on,can this problem be fixed easily?
It sound's like the battery need's to be replaced, the alternator can't be checked without the car started, to check the alternator measure the voltage across the battery, it should read higher than the battery voltage. if the voltage on the battery stay's at 12 volt's with the car started the alternator is bad.
Apr 18, 2009 | Ford Escape Cars & Trucks
My computer would not charge. I have an appple powerbook g4. I bought a new battery. I put the battery in. It charges. Now the computr tries to turn on it makes the start up noises but the screen is blank....
Hi, sorry to hear you are having problems,
Are you saying that your Mac was working fine with the dead battery but then when you put in the new battery, the Mac died?
Well, if that is the case it might be possible that the battery ran down to ZERO and the mac's internal battery also is dead so, it does not even know what hard drive to boot into...
So, with the Mac Shut Down, hit the power on button and then VERY QUICKLY, press the ( alt ) key and hold it until you see a blue screen with a Big right pointing blue arrow and a circular arrow.
You can let go of the key, and the mac is now looking for suitable startup volumes to boot from...
You should see your harddive appear after a minute or so... If it does not appear, then either your system is damaged or your disk is KAPUT...
How old is your Mac? It is very very common for PowerBook drives to die after 4 years without advanced warning... :(
Good luck
Mar 24, 2009 | Apple PowerBook G4 Mac Notebook
Mac Ibook Power supply problem
On Mac iBooks the orange light comes on when it charges the battery. Once the battery is charged it turns green. Im guessing the other powersupply was aftermarket or broken. EIther way, if it starts out green - recognizes the battery isnt full - turns orange for a while - then turns green when the battery is full, then the computer and powersupply are working perfectly. Enjoy your iBook!
Feb 27, 2009 | Apple Computers & Internet
Power problems Inspirion 8600-battery not charging
Most Dell batteries have an LED indicator that allows users to see how much run time and how much overall battery life are available at the touch of a button.
To check battery charge, press the button and the number of lights that appear will tell you charge status. If all lights appear, you have a fully charged battery. Each light that appears accounts for approximately 20% charge.
To check the battery health, press and hold the status button on the battery charge gauge for at least 3 seconds. If no lights appear, the battery is in good condition and approximately more than 80 percent of its original charge capacity remains. Each light represents incremental degradation. If five lights appear, approximately less than 60 percent of the charge capacity remains, and you should consider replacing the battery
if the ac adapter will power the laptop without the battery installed its fine. if the cord is fine and your battery is fine its a mother board issue and it will most likely have to be replaced
Feb 05, 2009 | Dell Computers & Internet
MacBook wont run from battery
Apple does have a battery recall/fixing procedure on certain macbooks and macbook pros.
The battery of a MacBook or MacBook Pro computer may:
  • Appear to have no charge (zero percent)
  • Be unable to power the computer by itself; the computer might work only when it is connected to the MagSafe power adaptor, which only shows a green LED
  • Appear with a black "X" icon on the menu bar
  1. Shut down, then remove and reinstall the battery. Test for the issue(s) again.
  2. Connect the MagSafe power adaptor (if you haven't already) and see if the behavior continues.
  3. If the issue(s) persist, download and install the Mac OS X 10.4.9 Update.
  4. If the issue(s) persist, Download and install Battery Update 1.2.
If, after installing the Mac OS X 10.4.9 Update and Battery Update 1.2, a black "X" still appears in the menu bar, contact apple by calling 1-800-MY-APPLE (1-800-692-7753)
Dec 06, 2007 | Computers & Internet
Wowee One Slim Portable Speaker for iPad, iPhone Mp3 WOW-00019 Logo
223 people viewed this question
Top Wowee Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Wowee Audio Player and Recorder Expert? Answer questions, earn points and help others
