Question about Cadet Manufacturing C152 Com-Pak Plus Heater
Cadet heater cs 152 not blowing hard
Not much heat comes out
3 Suggested Answers
  • 149 Answers
SOURCE: I just need a wiring diagram---with a thermostat--
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
Posted on Jan 16, 2010
SOURCE: my cadet c202 heater is running the fan is blowing
I work in a motel and replace these heaters quite often, Cadet C202, a 240v 2000 watt wall heater. Most of the time when they blow cold air it's because the heating element is broken. First turn off the circuit breaker, then remove the heater from the wall. If you take out three screws, slide the top cover off, bend the two little tabs and take out the heating element, you can examine it and usually you will find a place where it is broken, it's like a big spring. Replacement elements can be ordered from online stores such as reliableparts.com Be very careful, 240 VAC is very dangerous! <!-- from fixya rte -->
Posted on Aug 16, 2010
I have a cadet wall heater, the orange light comes on, i have to shut it off and turn it back on. It is blowing heat.
There is a little sensor called a 'flame sensor' that is inserted into the actual flame. Its only job is to complete a grounding circuit on the control board actually through the gas flame... By the description of your problem, it sounds like it either has oxidation on its surface OR the physical connections at the flame sensor itself or where it plugs into the control board have just enough oxidation to imhibit the signal from the flame sensor.
I would suggest calling the service center to have a tech look at it.
Dec 22, 2014 | Cadet Manufacturing Heating & Cooling
My cadet wall heater wont turn off
My cadet heater was doing this so I pulled it off of the wall and saw that the two wires coming from the thermostat portion had melted out of their insulation and were crossed. The heat is of some concern, but for now I just wrapped them in electrical tape to insulate them better against melting
Mar 11, 2012 | Cadet Manufacturing Built-In Wall Heater
When i plug in the insink erator and turn it on it blows the breaker is it the heating element or the switch or the thermostat
The first thing I would check would be the switch. then the thermostat then the element.I would also check for any burnt insulation which could allow a short to ground.
My gut feeling would be the element but I like to eliminate the less expensive items first. Hope this helps. Thank you and have a good holidays.
Dec 22, 2010 | Emerson InSinkErator W-152 Point-Of-Use...
FAN IS BLOWING BUT NO HEAT
hello,
this means that the heater of your cadet have been disconnect from it position or it has gone bad
please note this, that the heater is call element technically if you to get a replacement for it
what you have to do from here to fix up cadet is that unscrew your heart with the basic tools trace the maize i.e the wire down fan then trace the wire from the fan to the element it's always white in colour if it's properly connected from it position then you have to passive it if smiley borne meaning that it has gone bad then it will need replacement,
but if it is disconnected then you will have to do the fixing you self by peaking up the loss wire and fix it up back to the position
thank you and thanks for using fixya.
May 03, 2010 | Cadet Manufacturing 67507 Heater
I just need a wiring diagram---with a thermostat-- for a cadet FX-152 , 240 volt ,1500 watt wall heater
Jan 15, 2010 | Cadet Manufacturing CADET SL Series Small...
My cadet c202 heater is running the fan is blowing cold air but no heat, is it the thermostat or heating elements or both???or ?????
Dec 31, 2009 | Cadet Manufacturing 67507 Heater
Cadet Thermostat
from the mod number it looks like you have electric baseboard. these do not have blowers in them they work off natural air movement. but heat up rather quickly. your gonna have to chk if baseboard is getting power to determine weather or not the t stat or the heater is not working. but first chk your circuit breakers. most heaters are 220v (double breaker)
Mar 19, 2009 | Cadet Manufacturing 6F1500W Baseboard...
Cadet Manufacturing C152 Com-Pak  Plus Heater Logo
47 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
