Question about SanDisk Sansa e250 MP3 Player
Does not recognize the micro sd card
I load up the sd card with songs and insert it. The sansa does not see the card at all
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
First, make sure it's a microSD card and not a microSDHC card. If it's larger than 2GB then it's a microSDHC card and won't work. Second, make sure all your music is in a folder named "MUSIC".
Posted on Jan 11, 2012
SOURCE: Micro SD card not read
The Sansa c250 and lower cannot read SDHC cards. They must be regular SD cards for the c250 to "see" them. That is, they must be of 2GB capacity or lower. If the card is 4GB or higher, it is a SDHC card and will not work.
Posted on Apr 02, 2009
SOURCE: Sansa c250 Micro SD card not recocnised
You need to create a folder named MUSIC on the MicroSD card to copy your MP3 files into
Posted on May 10, 2008
SOURCE: sansa mp3 player could not detect micro sd add on card
Ok so as was mentioned its a SDHC card. and a v1 player won't play it.
you have a "v1" is your firmware starts with 01.xx.xx.xxx etc
to fix this you can "rockbox" your e260 (www.rockbox.org)
it makes the player much much better imo as well as allow it to read 8 gb sd cards.
though i have to put it in my card reader to add files not sure why but my player does read and recognize the files so thats a plus.
Posted on Feb 17, 2009
mikethompson
  • 155 Answers
SOURCE: sansa e250 using micro sd card
change the mode of the player to MSC and connected the player to the computer, this will help detect the microsd as a removable disc drive.Transferring songs to the card is via drag and drop or copy and paste.
Posted on Dec 08, 2007
Schmead10
  • 650 Answers
SOURCE: micro sd memory card not recognized
Make sure your usb mode is msc plugin your sansa and go to my computer click on Sansa folder and you should see your removable disk this is your expansion card
Posted on Apr 18, 2009
I inserted a 2gb micro sd card into my 4gb sansa fuze for more memory and it's still saying I don't have enough space on it when I go to add a song off of limewire
Inserting a microSD card into the Sansa does nto magically expand its internal memory. The card is a separate chunk of memory. You can move some songs from the internal memory to the card to free up some internal memory. Or you can add the new song to the card.
May 15, 2010 | SanDisk Sansa Fuze MP3 Player
2gb Sansa Fuze won't recognize 2gb Micro SD
place the blank card into the SanDisk player
go to SETTINGS press "enter"
go to SYSTEM SETTINGS press "enter
go to FORMAT press "enter"
it will ask "are you sure you want to format this device"?
select YES
dowload songs to REMOVABLE DISK drive F, at least that is what my PC assigned it to. You will overload your MP3 PLAYER if you continue to download to the Sanza Drive.
Hope this helps.
Aug 27, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
Use of micro sd card
If the memory card is over 2 GB, the player can not read it because it was only designed to read up to a 2 GB memory card. It is not showing up on your player because it is too big for the player to read. If you get a smaller card, it should woork just fine on your player and you should be able to access it easily.
Apr 05, 2009 | SanDisk Sansa e200 MP3 Player
Micro sd card
Does your computer has an internal card reader?
Aug 14, 2008 | SanDisk Sansa E280 MP3 Player
Mp3 Player not reading SD 1GB Card
The Sansa is unfortunatley one huge mess up the programming has failed its working on a database with only 4 levels but for grphics and songs you need at least 7 lhopefully you can return it and get another if not you can try putting another type of chip hopefully that will work
Apr 11, 2008 | SanDisk Sansa e260 MP3 Player
Sansa mp3 player could not detect micro sd add on card
Anything over 4GB is a Micro SDHC card, not a Micro SD card. It is a completely different type of card format on the inside, and despite the compatible size and shape, it will not work on devices labeled only as Micro SD card compatible. The Sansa e200 and up (e250, e260, ect.) are NOT COMPATIBLE WITH MICRO SDHC CARDS (Micro SD cards that exceed 2GB in capacity).
Dec 16, 2007 | SanDisk Sansa e260 MP3 Player
SD card in MP3 player
SD card = too big for player to read. Get a smaller SD card.
Dec 05, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
102 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
