Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Water leaking onto floor from under washing machine
WATER IS LEAKING FROM UNDER WASHING MACHINE INTO FLOOR, CAN YOU GIVE ME A LIST OF WHAT IT COULD BE, Thank you. V. Miller
    President:
  • Whirlpool Master
  • 2,651 Answers
First off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Posted on Jan 20, 2009
I have a Whirlpool washer, i put a new water pump on and i put a new drain hose on. And it's still leaking water on the floor what could be wrong.
on this machine common problem is look right under the machine right under the heater you will see its coming from there if its not from there it will have a split in the drum as the plastic is really fin have a good look you can arrowdite normaly will do the trick but make sore all water is gone ok
Oct 18, 2012 | Whirlpool Washing Machines
WHEN WASHING MACHINE IS FILLING WITH WATER AFTER APPROX 30 SECONDS WATER STARTS LEAKING ALL OVER THE FLOOR FROM SOMEWHERE UNDER THE MACHINE
The first thing to do is to have the leak investigated by somebody there as we could only offer a list of guesses ;-0)
Once it is empty and carefully lifted onto its side, it should be possible to inspect the hoses and clips and hopefully identify the culprit. In some cases it might even be possible to affect at least a temporary fix whilst obtaining the necessary spare.
Sorry we could be only of limited help in this instance- it's very difficult diagnosing this sort of problem remotely ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 09, 2011 | LG WD-80130F 7.2kg Washing machine
Leak at back of machine
A leak at the back of a washing machine can come from several sources.
It requires a good investigation.
Here are some of the first area to look at that are on the outside of the machine
1 Hot and Cold Fill Hoses may not be tight enough. So water can drip down the hose, or back of machine onto the floor
2 Drain Hose-Usually about an inch or so in diameter. Hose in new machines should not leak itself, but if it is not mounted or attached well enough into the drainage plumbing mounted on the wall (The box with the Hot and Cold Water Shut-offs, it will leak or splash water onto the floor during the drain cycle.
3 Damaged plumbing in the wall can seep under the wall and end up under the washer. This is very rare, but I have seen it.
4 There is a filter mounted behind a panel on the lower back side of the machine. It is possible a leak is occurring from that area. Take off the cover and see.
If the above don't handle it, the next step is for what is not easy to detect. Leaks inside the machine. You will need to go into it and LOOK with your eyes and a good flashlight.
Hope this helps,
Best, Mark
Dec 31, 2010 | Hotpoint WMA54 Front Load Washer
Leaking water onto floor from inside machine
2 common places.1 leak from the pipe/s from the valves to the dispenser box,2 @6 o/clock position in the fold of the door seal is where these models produce a small split.filter not tight.water bubbling over stand pipe when machine pumps out?these machines are usually fairly leak free so might be just one of these things i`ve listed here with luck.
Dec 29, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Leaking on the floor for several months
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Aug 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Maytag performa washer
check to see if the tub to pump hose has pulled off
Dec 18, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
764 people viewed this question
Dan Webster
Dan Webster
Sal De
