Question about Ignition System for Saturn Relay-1 FWD
2006 a6 audi no crank no starter
I need location of fuse and relay description
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Check battery connections.
Posted on Jan 06, 2014
Where are the fuse boxes located and how many are there? How many relays are there?
One fuse box is located under the dash on the passenger side. See operators manual
A second that contains both fuses and relays is located on the driver side under hood. There is a plastic snap latch that allows for it to be opened. On the back of the cover is a description of the circuits and locations of the fuses and relays.
Nov 15, 2015 | Cars & Trucks
Where are the door lock relays in the 2008 Avalanche?
FUSE AND RELAYS FOR POWER DOOR LOCKS SHOULD BE UNDER THE HOOD.LOOK IN OWNER MANUAL FOR RELAYS LOCATION OR LOOK ON FUSE RELAY COVER FOR RELAYS LOCATION..
May 08, 2011 | 2008 Chevrolet Avalanche
2000 ford explorer, fuse box don't show me what fuses are for
There are two fuse boxes. A baqttery junction box under the hood on the drivers side and one inside on drivers side. Good luck.
Fuse/Relay
Location
Fuse Amp
Rating
Power Distribution Box
Description
1 60A** I/P Fuse Panel
2 40A** Blower Motor Relay
3 50A** 4 Wheel Anti-Lock Brake System
(4WABS) Module
4 30A** Power Windows, Power Moon
Roof, Power Seat
5 50A** Ignition Switch, Starter Relay
6 20A** Transfer Case Relay
7 - Not Used
8 20A** Air Suspension
9 40A** Air Suspension
10 30A** PCM Power Relay
1 10A* A/C Relay
2 30A* Heated Seats
3 30A* Heated Backlight
4 15A* Fog Lamps and Daytime Running
Lamps
5 4 3 2 1
10 9 8 7 6
12 11 10 9
8 7 6 5
4 3 2 1
15 14 13
2 1 1
9
6
10
8
7
5
175
MEGAFUSE
Roadside emergencies
197
Fuse/Relay
Location
Fuse Amp
Rating
Description
5 - Not Used
6 10A* Powertrain Control Module
7 30A* 4 Wheel Anti-Lock System
(4WABS) Module
8 15A* Rear Wiper Motor
9 20A* Fuel Pump Relay and RAP
Module
10 15A* Horn Relay
11 15A* Parklamps Relay and Mainlight
Switch
12 30A* Mainlight Switch and
Multifunction Switch
13 15A* Heated Oxygen Sensor, EGR
Vacuum Regulator, EVR Solenoid,
Camshaft Position (CMP) Sensor,
Canister Vent Solenoid
14 30A* Generator/Voltage Regulator
15 - Not Used
1 - Wiper Park Relay
2 - A/C Relay
3 - Wiper High/Low Relay
4 - PCM Power Relay
5 - Fuel Pump Relay
6 - Starter Relay
7 - Horn Relay
8 - Rear Wipe Down Relay
9 - Blower Motor Relay
10 - Rear Wipe Up Relay
1 - Not Used
1 - DRL Diode
2 - Electronic Engine Controls Diode
Apr 06, 2011 | 2000 Ford Explorer
Need location of rear blower relay 2001 expedtion
Here is the order of checking....
Power Distribution Box Description
Position 114 30AMP** for Climate Control Auxiliary Blower
** MaxiFuse
Passenger Compartment Fuse Panel
Position 7 5AMP for Aux A/C Blower Relay (via fuse 22)
Position 24 10AMP for EATC Module, EATC Blower Relay, Climate Control Switch Assembly (Feeds Fuse 7)
Also, additional details about fuses could find in ford.com/maintenance/owners_manuals
Hope helps.
Feb 04, 2011 | 2000 Ford Expedition
Horn relay location 1999 Ford Escort
Hi!!
Check on the engine compartment fuse box by the battery, remove the plastic cap and look on the inside for the fuse location and description diagram. It should be labeled HORN. Check the Fuse first and then the Relay. To check the Relay, just swap it with another one with the same numbers on top of the relay. After testing, don't forget to replace the Relays to their original location. No need to turn key on since it is an Hot At All Time Circuit.
On some vehicles the Horn Fuse and Relay are located in the fuse box under Instrument Panel, driver's side.
Good Luck!! Don't forget to rate this post!!
Sep 20, 2010 | Ford Escape Cars & Trucks
A/c fuses . i just changed the front blower motor and now it wont come on i need to know what fuses and relay to check?
Check page 162 and next for FUSE and RELAYS description and location... Ford-Expedition-Owners-Manual
Several locations for your fuses and relays around A/C System... the fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the panel cover to access the fuses. To remove a fuse use the fuse puller tool provided on the fuse panel cover.
The power distribution box is located in the engine compartment.
The power distribution box contains high-current fuses that protect your
vehicle’s main electrical systems from overloads.
Relays are located in the power distribution box and should be replaced by qualified technicians.
Hope helps (remember rated this).
Jul 11, 2010 | 1999 Ford Expedition
I need to know which relay is the abs relay on my 1990 corrado
relay 13 is abs pump relay,relay 14 is abs relay
If you look at fuse box,there is a row of fuses,other end row of relays
You need to check second row relays,far left and next right
Apr 01, 2010 | 1990 Volkswagen Corrado
A/C Control Relay
There are several relays for the A/C system on these. Using the reverse of the lid of the fuse/relay plate box it will show you the positioning of the relays but not the description;
I've added in the description so hopefully will help you!
Relay 9 - Heater blower relay
Relay 10 - Heated rear window relay
Relay 13 - A/C condenser blower motor relay
Relay 14 - A/C compressor clutch relay
Relay 15 - A/C condenser blower motor relay
There is no relay itself for the A/C control, however there are a couple of fuses for this. If you need I can supply you with the fuse position and exact function within the AC system.
Out of curiousity whats the problem with your AC?
Hope this helps
May 12, 2009 | 2007 BMW 525xi Sedan
Fuel pump is not pumping on my ford ltd crown victoria. i need a fuse diagram so i can see if it is just the fuse or if i need to replace the pump.
There is both a fuse and a relay for the fuel pumps electrical system. The image below of the Power Distribution Box is located in the engine compartment.
Fuse/Relay Location: 5
Fuse Amp Rating: 20 Amp Mini Fuse
Power Distribution Box Description: Fuel pump
Fuse/Relay Location: 203
Fuse Amp Rating: 1/2 ISO
Power Distribution Box Description: Fuel pump relay
Apr 14, 2009 | 2003 Ford Crown Victoria
All 4 windows won't go down
_________________________________
Fuse Location: 11
Fuse Amp Rating: 10 Amp
Description: Ignition (START) - ON/ACC (window and decklid) relay coil and Police ON/ACC relay coil (Police vehicles only)
Power Distribution Box (Under Hood)
Fuse Location: 304
Fuse Amp Rating: Full ISO Relay
Description: RUN/ACC relay (windows and decklid) (police vehicles only)
Fuse Location: 602
Fuse Amp Rating: 20A Circuit Breaker
Description: RUN/ACC relay feed (windows and decklid) (police vehicles only)
Mar 26, 2009 | 2005 Ford Crown Victoria
Ignition System for Saturn Relay-1 FWD Logo
88 people viewed this question
Top Saturn Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Lawrence Oravetz
Are you a Saturn Vehicle Part and Accessory Expert? Answer questions, earn points and help others
