Question about Western Digital My Book Essential 320GB External USB 2.0 - WDH1U3200N Hard Drive
Wd3200h1u-00 intermittent off and on
My external hard drive continues to cycle on and off while I'm trying to access contents. Anyone know why this condition?
SOURCE: Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
Posted on Nov 18, 2009
  • 739 Answers
SOURCE: Can't drag items into WD external hard drive (Mac OS X)
OK Where did the files on the drive come from if you can't write to it?
I'm suspecting that It's come from a PC and the disk is formatted NTFS.
Macs can read the NTFS but cannot write to it. They can read and write to FAT and other DOS formats.
If you are only going to use it on your Mac then you will have to reformat the drive.
First, copy every file you need to keep onto your HD (if you have room) then use Disk Utility (in the Utilities Folder) to erase and refomat as Mac OS Extended (Journalled).
Then copy all your files back on
If you need to use the drive on both Mac and Windows use the MS_DOS (FAT) option.
Posted on Oct 17, 2009
darkpain
  • 316 Answers
SOURCE: i am having an issue with my WD5000h1u-00 500 GB external drive
Read this instructions my friend
It is possible to use a Western Digital external hard drive on botha PC and a Mac. However, there are some things to keep in mind if youwant to do this. Moreover, Western Digital does not recommend doing it.
  • For both PC and Mac to be able to read the drive, it must beformatted in the FAT32 file format. In order to format to FAT32 on aMac you may need to contact Apple for support. We do have a FAT32Formatting utility for Windows that reformats WD external hard drivesto their full size, but in only one partition. The FAT32 formattingutility can be downloaded from our Downloads Library. You will find it on your WD drive's Downloads page.
  • Critical: Do not attempt toconnect any external drive to multiple computers, simultaneously; letalone to both a Mac and PC. This could quickly damage the drive'spartition and corrupt the data on the drive.
  • Sometimes, PC's won't read Mac FAT32 formatted drives, andMac's won't read PC FAT32 formatted drives. You may have to re-formatthe drive trying both the PC and Mac until you get a format that works.
  • Most WD external hard drives come pre-formatted with one large FAT32 partition, which is accessible by Windows 2000, XP, and Vista, and Mac OS 10.4 and 10.5.
  • Windows 2000, XP and Vista can only create FAT32 partitions that are 32 GB's or smaller.
  • Mac 10.4 and 10.5 can create FAT32 partitions the full size of the drive.
  • There is a 4 GB file size limit on the FAT32 file format. Thisis a file system limitation that affects both Mac's and PC's, and thereis no way around it.
  • Finally, you need to understand that if you are using the samedrive back and forth between a Mac and PC, there is always the chanceof files being corrupted. Mac's and PC's are different platforms, andtheir file systems function differently. Please keep backups of allyour files before you start sharing between Mac and PC computers.
Note: Once the data iscorrupted, that drive may no longer be recognized by one or both of thecomputers. Or, the drive may be recognized, and the data may bevisible, but you won't be able to open any files. At that point, youwill need to re-partition and reformat the drive in order for it to berestored and usable by both computers again. In the process, you willlose all the data on the drive. For that reason, you need to keep abackup of the files you are transferring between computers.At the bottom of the page, you will find links for partitioning and formatting in Windows XP and Vista, and Mac 10.4 and 10.5.
Posted on Jan 12, 2010
SOURCE: WD external Hard drive 320 GB hangs my computer everytime connect
all solutions are not helpful, if u just use safe mode then there is no problem with hard disk, its a problem of some services, u just try with safe mode.30-40% people has same problem.
girish
Posted on Feb 05, 2010
dragoneyes76
  • 105 Answers
SOURCE: My WD External Passport HDD is not accessible. The
Hi.
You have to install WD Smartware, which is located on another drive.
THen you will have access to it.
Otherwise the drive is damaged.
God Bless You!
Posted on Feb 05, 2011
Don't know to transfer my PC hard drive to my Seagate external hard drive (1T)
You can copy paste the contents or cut and paste or right mouse click on contents and click "send to....external drive" Once the contents is on the external drive this can be taken to another PC and copied back. Caution: Some contents can be very LARGE and take a LONG time to be copied! It is advisable to run a BACKUP every now and then. And be sure your external drive is working correctly (Scandisk).
Mar 27, 2013 | Computers & Internet
I have a MSI U135dx , i have a screen here that says Realtex PCI Express Fast Ethernet Controller Seris v1.15 ( 090224) PXE-E61: Media test failure, check cable PXE-MOF : Exiting PXE ROM Reboot an
The Problem with your laptop is that it is trying to boot from a LAN instead of from your hard drive. Put your hard drive back in and hopefully the operating system is still there and then boot your laptop, and look at the screen for key to hit to get to BIOS or System Setup. Once in the BIOS check your Boot Order and make sure the Hard Drive is first.
Apr 07, 2012 | MSI Wind Computers & Internet
Please say someone has a solution for me, very worried i've most my life's collection of music and movies =[
Try the WD USB hard drive in another computer. If you can access your data on another computer then backup your data.
If the WD USB hard drive is faulty then -
It is not possible to recover data from faulty hard drivesby mortals such as you and I.
There are companies that can recover data from faulty and damaged hard drivesBUT they wll charge an arm and a leg for their services.
Feb 23, 2012 | Western Digital 1TB WD ELEMENTS USB...
What is rpm for wd3200h1u
Transfer Rate - 480 Mbits/sec.its probably 7200
Oct 22, 2009 | Western Digital My Book Essential 320GB...
I dropped a my book external hard drive
The hard drive could be damaged but the USB adapter case electronics is OK. Therefore the computer can see the USB device (adapter case) but not the hard drive. If the hard drive makes a clicking noise or you cannot hear the hard drive spin, then the hard drive is definitely faulty.
Oct 22, 2009 | Computers & Internet
1600XMSB-00 western digital & it won't show when i plug it in
Did you try your drive in another computer? Check if all the cables and the power supply if any are proper.
Jun 23, 2009 | Western Digital External USB 2.0 80 GB...
My Book Essential Edition 2.0 Model WD3200H1U-00 Drivers missing
I would recommend Uninstalling and then RE-Installing the Drivers/Software. Have you looked here:
Home Edition:
http://support.wdc.com/product/download.asp?groupid=111&sid=59&lang=en
Select your model here if different than above link:
http://support.wdc.com/product/download.asp?wdc_lang=en
Is Western Digital site for latest Driver and Software.
Let me know if this helps
Jun 10, 2009 | Western Digital My Book Essential 320GB...
External hard drive
ya yiu can do it only you need is to download the drivers from the homesite of teh type of hard drive u r using
u hav not mentioned the name her so just simply try by searching google for the driver
Jul 28, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Western Digital My Book Essential 320GB External USB 2.0 - WDH1U3200N Hard Drive Logo
95 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
