Question about HP ProLiant DL380 G4 Server
Best SCSI Hard Drive Diagnostic tool for HP Hard Drives?
I was wondering if anybody knows of a good utility that provides proper diagnostics for HP SCSI Hard Drives (from the Proliant Server Series). I have four hard drives that are suspected to be faulty however i need to prove that there is something wrong. The HP Insight Diagnostic does not provide enough information and other information produced by the Array Configuration Utility (ACU) does not indicate there is a problem. Plus the reports produced by the ACU are not so simple to understand because everything is written in Hex.
Can someone recommend a tool (whether it requires to be installed or burned to a CD and boot the server with it) that has the capability to fully test and scan SCSI hard drives on a server?
    Problem Solver:
  • 17 Answers
Hi there you have the insight diagnostic cd boot the server with it then when you boot be careful not to erase the server there you will find the offline diagnostics tool where you can select the HDD you want to diagnosis if the hdd fails it will alert in red color its that sinmple
Posted on Jan 24, 2009
Will not recor .@ i can't reformat the hard disc
Try to save all your data, guess your hard disk is failing.
OK, it's just a general idea; you should check your hard disk's status with a diagnostics app:
Check some tools from here
Think You Might Have Hard Drive Problem Test it for Free
Best Free Hard Drive Health Monitoring and Diagnostic Programs
HDDScan free HDD diagnostic utility
Top 20 Free Disk Tools for SysAdmins
Aug 23, 2015 | Computers & Internet
Hi: i have hp server ML 370 with array smart 642 controller and i replace hard drives to clean and check but when turn on the server get me many messages no scsi boot device found and next line scsi bios...
when did this beast last work.
see the manual yet>
there are many 370s ,which one, the full service tag answers that.
G , 2, on up. 9????????????
Proliant servers.
use google to find old manuals.
here is g2
https://www.manualshelf.com/manual/hp/hp-proliant-ml370-g2-server/compaq-proliant-ml370-g2-service-update.html
here is HP site covering retired products, I suspect your is..
https://www.hpe.com/h20195/v2/Library.aspx?doccompany=HPE&cc=us&lc=en&filter_status=rw#&doccompany-hpe&sortorder-csdisplayorder&teasers-off&searchword-Compaq%20ProLiant%20ML370&isRetired-false&isRHParentNode-false&titleCheck-true
HPE has the , 642 book here. (just a spec)
https://www.hpe.com/h20195/v2/GetDocument.aspx?docname=c04284123
if read that page it tells you the controller is only works with
SCSI
Compatibility with all Ultra320, Ultra3 and Ultra2 LVD family products.
it also tells you , it needs the HP utility tools to set it up properly
why would your clean disks boot? why say that?
what does this mean?
"and i replace hard drives to clean and check" surely you can elaborate the full story,
last run when?> what G number is it.
what drives , make and model. installed.
do you have the software setup seen on page 5 link just above.
quote
All Smart Array products share a common set of configuration, management and diagnostic tools,
including Array Configuration Utility, Array Diagnostic Utility (ADU), and Insight Manager.
this product is offically retired, by hp and only few books there.
but google finds many books, 15 years old now. (as old as...)
http://kmcs-service.austin.hp.com/km-ext/kmcsdirect/emr_na-c01127202-1.pdf
see this, it tells you what to do in 77 pages.
my guess is you get lost at Set the boot controller
(Chapter 4).
my guess, is that you have no HP sofware support kits.
just hardware there.... right?
next time tell the helper, full spec on 370 Gn G numer.
and full spec , on 642, version. and that you dont have the HP software kit to support this machine, it's no simple desktop, no at all.
at the least you get stuck here,
Create at least one logical drive, as described in Chapter 5.
Sep 25, 2017 | HP Compaq ProLiant ML530 Server
Printer is on, does not copy, fax or scan, screen sez Hewlet Packard with right facing arrows.
Find and Fix Common Printer Problems Using HP Diagnostic Tools Review the following sections to learn about the diagnostic tools that HP offers, and then follow the links to learn how to download and install the tools. You can also use the following shortcuts to go to the section in this document that is related to your issue: HP Network Diagnostic Utility HP Print Diagnostic Utility HP Scan Diagnostic Utility HP Network Diagnostic Utility Network connectivity and communication is everything when it comes to networking your HP printer. The Network Diagnostic Utility provides help and information that is necessary to resolve network issues, including:
  • Verifies network and wireless connection status for your computer and the HP printer
  • Identifies security type and security key for your network
  • Identifies firewalls and supplies related help
Learn more!
Using the HP Network Diagnostic Utility (c02037530) (in English)
Oct 27, 2010 | HP LaserJet 3055 All-In-One Printer
Can't delete document. printer won't print
Learn more!
Oct 27, 2010 | HP Deskjet 3845 InkJet Printer
Printer is saying there is a paper jam. we went through all the steps to clear a paper jam but the carriage just grinds and doesn't move, then the error message reappears. Would like to be able to take the...
Learn more!
Oct 27, 2010 | HP Photosmart D7160 InkJet Printer
Raid degraded
If you are running a Intel processor, please go to the Intel site and use their free scan for Intel drivers utility. Install an updated RAID controller and then try to sort out the issue using Device Mgr.
Sep 02, 2017 | HP NetRAID-2M SCSI Controller
I have a maxtor 6L080M0 hard drive that has crashed The return code is 7 Is there any way to fix this problem.
If the following determines you have hard drive failure then you may have to purchase a new HD. Follow what is recommended from the manufacturer below. READ EVERYTHING.
According to Seagate the makers of Maxtor, you have a DiamondMax 10 (6L080M0). See below or click here
My internal hard drive may be defective, how can I test it?
Question
My internal hard disk drive may be defective, how can I test it?
How can I determine if the problem is with my system or with the hard drive?
It is necessary to run the SeaTools, SeaTools Enterprise, or SCSIMax diagnostic before contacting Technical Support 1.800.SEAGATE (1.800.732.4283) on an internal drive that may be defective.
Answer
For Seagate or Maxtor (or Quantum) ATA drives:
If this is a Seagate or Maxtor (or Quantum) ATA or SATA drive, please download the SeaTools for DOS diagnostic to test it. If the drive is failing, the tests in SeaTools for DOS will indicate as such.
If the BIOS does not recognize the drive or the drive does not spin please reference Answer ID: 48
The operating system will not recognize a drive that is not formatted and partitioned. If you need help with formatting:
  • Windows 9x and ME reference Answer ID: 3076
  • Windows 2000 Answer ID: 880
  • Windows XP Answer ID: 3361
  • Windows Vista Answer ID: 3844
  • Macintosh Answer ID: 492
    For Seagate SCSI drives:
    Please download the SeaTools Enterprise Edition diagnostic.
    For Maxtor (or Quantum) SCSI drives:
    Please download the SCSIMax diagnostic.
    SeaTools, SeaTools Enterprise, and SCSIMax will test your S.M.A.R.T-compliant ATA, SATA, or SCSI disk drive for media defects, perform a read test, physical head test and ensure the hard drive is functioning correctly.
    If all the tests pass (no trouble found), the problem remains elsewhere in your system. Reconfirm all settings for hard drive jumpers, cables, and ATA, SATA, or SCSI controllers, and disk operating system. Consult your host controller documentation or system manufacturer for assistance with SCSI termination or ATA / SATA controller capabilities.
  • Jul 04, 2008 | Computers & Internet
    Drive array problem
    Hi Nick ,
    As of now you can Select "F2" to accept data loss and re-enable logical drive. This Load OS Normally .
    It seems that one of the HDD in the RAID 5 has failed , Did you notice any LED indications like red or amber on the HDDs ?? if so get that hdd replaced . Make sure the Failed HDD is replaced .
    You can run the Array Diagnostic Utility from HP System tools to check the Failed Drives and also frimware version of the controller . If the frimware is not latest Update it from HP website. DL380 G4 should have Smart Array 6i controller .
    Hope This was Helpful
    cheers :)
    May 17, 2008 | HP Compaq ProLiant DL380 G4 Server
    DVD combo drive not working
    Did you set your jumpers correctly? How about using a different power Cable? Different Data Cable? If all fails try diagnosing the problem. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps
    Sep 22, 2007 | Samsung SD 616E (729507925578) Internal...
    Hardisk cant be detected
    hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
    Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
    HP ProLiant DL380 G4 Server Logo
    2,849 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
