Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Frigidaire JSI-26 refrigerator side does not keep cold. Freezer works fine...
Refrigerator does not work. Freezer does.
  • 691 Answers
They share the same compressor so either the fridge air demand switch is faulty or more likely you have faulty thermistors.
Posted on Jan 06, 2013
Master_Tech
  • 770 Answers
SOURCE: The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Posted on Feb 17, 2008
farfield
  • 462 Answers
SOURCE: Problems with Frigidaire Refrigerator not cooling
In turning it off you may have only closed the air damper. Set it to 1/2 way.
If ice or frost in the air damper area on refrigerator side you may not be defrosting the freezer coil.
Inspect from bottom looking up with a mirror and flashlight. You should have no Ice buildup frost that is even and white is normal. Feel Check the back wall mid way down to 1/4 way to bottom. Push on the wall slightly. Crunching like frost or snow behind wall is not normal. I suspect non defrosting here.
Next eliminate the inside fan motor. It has to run to push air all over the freezer and refrigerator. If this fan doesn't run the results will be only the area with the refrigeration evaporator coil will cool and it may get too cold and resemble a non defrosting situation where the air is not able to circulate because of frost build up.
Next eliminate the Ice maker and light as a source of heat. Unscrew and unplug them
Next eliminate the door gaskets from not sealing. A piece of paper set tween the door and frame and pulled across it and you feel resistance all the way and the gaskets are smooth and not warped they are OK
Next inspect the condenser fan and coil by the compressor underneath. A dirty coil here will cause diminished heat removal and possible for a partial cooling of some of the freezer.
Only after inspecting all these items and determining they are OK should you proceed with refrigerant checking. Also a person with out the ability to measure the actual amount of refrigerant being put in should be shown the door. Even with topping off (adding some) refrigerant I use a scale to determine that I do not put in too much. So if you have a friend that does this and no way to tell how much is too much.... well with all due respect your getting what you pay for.
If this helps you understand your problem and need more information please post back, I will follow up. If it helped you determine your trouble please rate me as high as you can. Thank You for using fixya and good luck.
Posted on Mar 22, 2009
  • 531 Answers
SOURCE: frigidaire side by side freezer not freezing but
you may have defrost problem check see if you have frost build up in the freezer back wall
Posted on Apr 07, 2009
SOURCE: Refrigerator does not work
The plug for the damper door is not connected properly
Posted on May 24, 2009
  • 10 Answers
SOURCE: refrigerator is NOT getting cold
sounds like the thermostat
Posted on Sep 13, 2009
How do I tighten door handle on frigidaire model jsi-26
Good Morning Chris, thank you for your inquiry!
From my understanding you need to tighten the door handles on your Frigidaire refrigerator. I was unable to locate any information on your model JSI-26. Without the model number I would be unable to provide you with proper instructions on how to tighten your door handle. Could you please provide me with your model number? You can locate your serial tag (which lists your model number) on the right hand wall of your refrigerator. With that information I would be able to assist you further. -Matt
Aug 01, 2015 | Frigidaire Refrigerators
Refrigerator stopped working after it was opened or a while
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 30, 2011 | Frigidaire FRS6LE4FW 26 Cu. Ft. Side by...
Freezer side working fine - fridge side simply not cold enough even at highest setting
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire JSI-26 does not keep cold
It could be the thermostat, if its a mechanical one its easy to replace but if its electronic then its a cicuit board repair, theres two transistors which control the switching on and off when the censor triggers them. It could also be the compression system. There is a recharge kit which puts a special fluid into the system which regenerates it.
Mar 26, 2010 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
481 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
