Question about Dyson Dc-18 "slim" Upright Model Replacement Motor Filter Part
Suction the head clogs up and won't get good suction hair is sticking to head
4 Suggested Answers
  • 389 Answers
SOURCE: Suction problem? The carpet fiber and pet hair
You've probably got a lesser blockage further down the pipework, which is reducing the airflow. Check everywhere possible for blockages, and also make sure the washable filter is clean and dry.
Posted on Feb 05, 2010
  • 389 Answers
SOURCE: great suction through handle, no clogs anywhere,
OK - there are two obvious things to check: 1. Make sure the brush is rotating. The DC14 has a 'brush control system" operated by a knob on the base in front of the right side wheel. Make sure this hasn't accidentally been moved to the "off" position. With it in the "on" position, switch the machine on, tilt the handle back and check that the brush roll is rotating. If it isn't, then there's a broken belt or a problem with the clutch mechanism in the brush control system. 2. If the brush is rotating, switch the machine off (and unplug it), turn it over and you will see a short length of clear plastic hose with spiral reinforcing that runs from the brush area to the motor. That hose often develops a split (which lets air in and reduces suction around the brush). Take that hose off (pull it off from the motor end and then unscrew it from the brush end) and inspect it carefully for any damage. If it is damaged, get a new one - don't try and repair the old one, it's not worth it.
I hope this helps - if so, please remember to rate my response. If you need more help, just post a reply here and I'll see what more I can do. Good luck!
Posted on Feb 11, 2010
ercupa190
  • 12223 Answers
SOURCE: Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
Posted on Sep 17, 2012
Why has my vax power VX2 hoover now lost it's suction ? I have noticed that the roller has limitied brushes on it now and was clogged with hairs . I have removed this now and the brushes are still min
Sounds like something is clogging up the pipes between the head and suction pipe. Have a poke around with some wire to see if it's full of hair or fluff, maybe even a sock?
Sep 16, 2014 | Vacuums
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Dirt Devil Ultra Vision vacuum- no suction?
Check for a clog at the neck of the "bag".
Sep 11, 2017 | Dirt Devil Vacuums
Brissell proheata 2x doesn't have suction or the red brushes won't rotate on the hand tools?
Check the brushes for hair or some other clogging material and remove it. If the brushes can't spin freely, there is not enough suction power to make them spin.
Sep 17, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
The air turbo head for my miele flamenco II S251i spins but doesn't have suction
Check all the filters as well. We have dogs and the hair clogs up the filters. We take a air hose threw our vacuum once a month and it works like new again without replacing anything
Jun 07, 2012 | Miele Vacuums
We have a Miele Silver Moon vacuum that isn't
Hi dear.There are two type of attachments for this vacuum cleaners to pick up the pets hair,fluff & so on.They call it"Turbo & Power Brush".Turbo brush operates with machines suction & Power one operates with small electric motor which is built in the unit.They work with the same prenciple.There is a belt drives the rotary brush.OK.there are two small yellow screw underneath the unit.Please undo them,take of the cover & clean the rotary brush,check for the belts tension.It should be enough tight to drive the brush.If not ask for spare part from Miele in your country.After cleaning please put it back in order.To test it,attached to the vacuum.Turn the power on for Turbo brush,as long as suction starts,brush should start turning too.For the Power one,there should be power button on the handle to turn it on & off.Press it.It should work.On both of the unit,brush should spin good & strong enough to do the job when it's attached the surface you are vacuuming.Check the brush after each use,cleaned if neccesary. I hope that helps.Thanks.
Aug 01, 2010 | Miele s558 Silver Moon Vacuum
No suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
Sebo automatic x1.1 loss of suction
Check that the dust channel from the sole plate/brush head isn't clogged. Open the trapdoor (usually orange in colour on the base) and inspect the dust channel - sometimes dog hair can get trapped between the main dust channel and the feeder. Other than that take off the main hose and see if there's a clog down there as well as the main part where the wand locks in at the back. Its reasonably easy to get a clog out from a Sebo X range model.
Jan 16, 2009 | Vacuums
Dyson Dc-18 "slim" Upright Model Replacement Motor Filter Part Logo
13 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
