Question about Western Digital My Passport Essential 500GB External USB 20 Portable Red 500 GB Hard Drive
Western digital humming sound
Upon powering up the hard drive (plugin the usb cable to my computer), I can hear a clear sound (kind of like humming) with clear patterns. This definitely doesn't sound like the hard drive is being scratched or anything, the sound looks like some kind of alarm sound with recognizable patterns for fixing purposes. But I can't find anything anywhere about this. Checked in the manual and didn't see anything. Same with google searches etc... On top of that my hard drive is not detected by my computer as a hard drive. Although it detects that a new device has been pluged in. I don't feel or hear the drive rotating so I know something is wrong but I wondered if that sound could help me figure out what is the issue.
    New Friend:
  • 8 Answers
I'm 99% sure the heads are seized to the platters on this. The buzzing, or humming sound you hear is the spindle motor trying to spin up, but it can't. This is also why the drive is not rotating. Definitely do not power this drive up any more if the data is important to you. If this is one of the smaller Passport style drives, it's pretty common for them to literally rip the read/write heads off as the drive tries to spin up. Professional data recovery is the only option in these cases.
Posted on Jan 23, 2013
3 Suggested Answers
  • 163 Answers
SOURCE: My western digital Passport 320Gb usb drive is not detected
U need to update windows XP , USB drivers will be installed
Posted on Dec 29, 2009
rajeshpait
  • 542 Answers
SOURCE: i connect the hard drive to my computer my
Go to disk management and check whether the externall HDD has been detected and drive letter has been automatically assigned.
Thank you for using Fixya.
Posted on Jun 21, 2010
It powers up for a few secound and thencuts off
it sounds like a power issue check all leads attached to your external western digital make sure they are securely seated and are not faulty
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 25, 2011 | Western Digital 500GB My Book Pro-External...
The computer does not detect the hard drive, but i hear the disk that spin so it means that works
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Jun 09, 2011 | Western Digital My Passport Essential...
My western digital 1tb hard drive is freezing my computer and its not showing up as being connected to my computer
IT is a clear indication that the data transfer from the External hard drive is not compatible with the processor and can be resolved by changing the usb cable.
Jan 21, 2011 | Western Digital My Book Essential 1TB...
All of a sudden it's not turning on. My Hard drive is plugged in and I can hear it start to run, but the light doesn't go on and it doesn't show up on my computer no matter how many times I press the on...
It sounds like it powers up ok, but there is a problem with either / or the USB cable or USB port on the computer.
Try using a different cable if possible - if still no luck, try to connect to a different USB port on the computer. Older computers were built back when a USB port needed only power a mouse or keyboard. Nowadays, USB ports are powering devices with much higher power requirements. If yors is such a machine, you may have damaged the port. You can get around this problem by using a powered hub between the computer and the drive. The power from the hub will provide the power for the drive, so there will be no power taken from the computer to spin the drive.
Please rate my reply and good luck!
Sep 02, 2010 | Western Digital My Book Home Edition 500...
My western digital 320 gig external hard drive stopped working all of a sudden. it has not been physically damaged. when plugged in the lights just blinks.
you told that it has not been pysically damaged than why light just blinks ok first you see the cable is in good condition. next plugin you hard disk to your computer and listen if any kind of sound coming through your hard disk (sound is like tee tic) if the sound out comes like what i said some way it stuck or damaged let me know if it works
Aug 12, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Dropped wd, not recognized by computer
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 21, 2009 | Western Digital My Book Essential Edition...
Need help with western digital wd3200me passport
if it came with a driver disk or an install disk then try running that before hooking up your harddrive
Jun 01, 2009 | Western Digital Elements powered by WD 320...
Western Digital hard drive problem
Ok.  I have a WD 500 and I have ran into similar problems.  First, shut your computer down.  Unplug the hard drives USB cable and the power cable.  Wait for about 2 minutes.  Plug the USB cable into the computer, plug the power cord in...wait for 30-45 seconds and then start your computer.  That hopefully should solve your issues.
Mar 01, 2009 | Western Digital My Book Essential Edition...
Open Questions:
Western Digital My Passport Essential 500GB External USB 20 Portable  Red 500 GB Hard Drive Logo
293 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
