Question about Refrigerators
How do you defrost refrigerator model gsl25jf
How to turn my refrigerator off to defrost
Your model has a control Board that most likely automatically controls periodic defrosting. If it's not defrosting, then that Board, the heater, or defrost thermostat is bad.
Sep 07, 2017 | Samsung Refrigerators
How to replace defrost timer
There is not a defrost timer on a model PSC23NGN. If your model is the=> PSC23NGN and the refrigerator is not defrosting the problem is most likely the Defrost Heater and Defrost Thermostat that need replaced. The heater is item location 230 and the defrost thermostat is item location 240 in this photo=> HERE
The part numbers for the Defrost Heater are WR51X10055 Defrost Heater Assembly The part number for the Defrost Thermostat WR50X10028 Defrost Thermostat
I am here if you have questions, Thanks John Tripp
Appliance 911
Contact me here.
Jul 06, 2014 | GE PSC23NGN Side by Side Refrigerator
The bottom part of the refrigerator is not cooling, freezer is ok
Are you sure about the model number being MTF2153GES? Usally when the fresh food section warms up it is an indication that there is a problem with the defrost system. If your model number is correct MTF2153GES then the refrigerator has a defrost timer behind the controls inside the fresh food section. I need to see if the defrost timer is stuck and causing the refrigerator to miss defrost. The defrost timer is=> 68233-3 Defrost Timer Let me know about the model number so I can continue to help solve this problem. . I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 11, 2014 | Maytag MTF2156GES Top Freezer Refrigerator
Defroster not working
The WR51X322 Defrost Heater Assembly
could be burned out in your model. Can you look inside the fresh food section and find the model number for me. The answer to the problem on your model depends on having the correct model number so I don't miss other parts that may cause a defrost failure. I know you said Monogram Side by Side but that does not tell me for sure what the Model Number on your refrigerator is. If your model is like the models in the GE Monogram Refrigerator Service Manual the I can have an idea of those parts. Those models have the defrost controls as part of their motherboard and that board does not fail at least in the defrost part of the board. defrost very often. You may need to also test or replace the WR50X10088 Defrost Thermostat I will be here should you have questions Thanks Sea Breeze
Apr 07, 2013 | GE Monogram Side by Side Refrigerator
Refidgerator side is warm freezer still working but not defrosting
Your model refrigerator has a 241508001 Defrost Control Board
found as part listed as location 23 HERE
and is the most likely cause for your refrigerator not defrosting. The other causes can be the 5303918255 Defrost Heater
instructions on testing can also be found on the same page as the defrost heater. The last part to cause defrost failure is the=> 5303918214 Defrost Thermostat
Item 14 is the defrost heater and item 21 is the defrost the
rmostat and can be found in the photo found on this page HERE
Let me know what you find so I can answer your questions, Thanks Sea Breeze
Oct 04, 2012 | Kenmore Side by Side Refrigerator
I have a gsl25jf side by side. Ice will not dispense - ice continuess to be made. Water will dispense - after you try to have ice dispense from the door there seems to be a clicking sound the lights dim on...
PULL THE ICE DESPENCER OUT AND RUN HOT WATER OVER IT AND START FRESH . IT MIGHT JUST HAVE A ICE JAM, I HAVE SEEN THIS BEFORE, THE ICE BUILDS UP IN LAYERS AND WONT ALLOW THE TREY TO SIT IN SNUG TO THE MOTOR .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | GE GSL25JFPBS Side by Side Refrigerator
I have a side-by-side refrigerator model #
This is an auotmatic defrost system. If you have severe frost build up on the back of the freezer wall you have a defrost problem. Either defrost timer, Defrost terminator (t-sat) or defrost heater.
Jan 27, 2010 | Refrigerators
GE Frig has water at door but no ice is made
Pour about 1/2 cup of water into the icemaker . If it dumps , replace the water valve . If not , replace the icemaker . Make sure the coils are clean of dust , etc... at bottom of fridge .
Aug 09, 2009 | GE CleanSteel GSL25JFTBS
Need location of defrost timer
The refrigerator you listed does not have a defrost timer. All defrost and refrigerator functions are controlled on rear of the refrigerator. It's called a mother board. If it s damaged you will sometimes see burns on one of the both sides, but not always. Another problem could be that your defrost element or defrost thermostat is defective. You can see your refrigerator below by putting the model GSS201EMBWW into the model search feature. I am here to help you if you want, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Here is another link here on FixYa that shows the mother board
http://www.fixya.com/support/t230703-ge_refrigerator_stopped_working
May 28, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
