Question about Blackburn Flea Light Set
Rear Light will not stay on
After been recharged for the first time, Flea 2.0 will not stay on after the power switch is released. The light is fully charged but works only as long as the power button is pressed. Tried to switch off and on, but still the same. Tried to change from "demo" by holding the power for 30 sec. but no change.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 57 Answers
Sounds like a bad contact in the switch. This seems to be a common problem.
Posted on Jan 12, 2013
My break light swithes on sometimes without me even pressing the breaks. The break light also sometimes stays on even when I have taken my feet off the break. I have tried changed the break light switch...
Did you adjust the brake light switch correctly? To adjust the brake light switch, first press the brake pedal down a few inches, then pull the switch plunger rod out of the switch toward the brake pedal arm, as far as you can without using excessive force. Next, return the brake pedal to the pedal stop position against the pedal stop and pull the brake pedal toward the rear to push the brake light switch actuating plunger rod into the switch housing limited by the travel of the brake pedal arm rear travel stop position. This procedure automatically adjusts the brake light switch correctly.
If the brake lights still don't turn off with the brake pedal released, check the brake pedal arm for sticking or binding that is preventing the brake pedal arm from returning fully to the pedal stop when the brake is released.
Feb 21, 2011 | 2002 Audi A4
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
Subaru legacy power lose when switched off. new battery charge rate 14 volt+
The charge rate of 14 volt shows that your alternator is responding as it should and is doing its best to recharge the battery. Even with a fully charged battery if you switch on the power hungry electrical items (main headlights, rear window demist heater etc) you should see the alternator respond by pushing out 14+ volts. A low battery will show about 12.2 volts when disconnected. OK you need to find what is draining your battery when the car is switched off. With the car off disconnect the negative terminal and measure the current flowing between the disconnected cable and the negative terminal, it should very very low, just enough to keep the clock running. If you do have residual current flow, remove and return each fuse one at a time and note each time the current reading. Quite quickly you will be able to isolate the circuit that is causing the drain. Often it is a lighting circuit for an interior light that you cannot see....such as a glove box light not going off when the lid closes or the trunk light staying on. These work by a contact switch being opened by coming into contact with a bracket when shut. If for some reason the bracket gets bent or is dislodged then the light stays on.
Jun 01, 2010 | 1992 Subaru Legacy
How do I insert the battery into the Blackburn flea?
It's a rechargable light, with a built in battery and no supposed user replacable battery. You need the USB dock to charge it either through your computer or using the optional Blackburn solar panel.
Jan 16, 2010 | Blackburn Flea Front HL Bicycle Headlight...
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 | Drills
I cannot get Blackburn flea to take a charge. It only the 2nd time I am recharging the rear flea. Its a brand new battery.
It might be stuck in 'display mode' (described on the package). Try holding down the button for twenty seconds until you see the signal. Then try turning it on normally again.
Aug 29, 2009 | Blackburn Flea Rear Flasher Bicycle...
1971 Olds Cutlass Supreme. Dash brake light stays
They are unrelated. Just make sure your brake release is fully relesed. The switch turns the light on if the release isn't against it fully.
Jul 14, 2009 | Oldsmobile Cutlass Cars & Trucks
My Flea Taillight won't charge, I'm using a brand new "AA" battery, (hooked up - red to + and black wire to - ) I've reset the "light from demo mode (holding down the button for 20"...
Try cleaning the contacts with a cotton swab and som isopropyl alcohol.
Let those dry.
Use a paper clip, or other small pointy object to clear the area around the contact points on the light so the recharger can fully "snap" into place.
Attach a battery you know has a good charge.
Turn on the light.
Did the light turn on?
If so, great, turn it off, and if it is blinking, let it recharge.
If it didn't turn on, isn't blinking and won't hold a charge after this process, return it to Blackburn and enjoy the benefits of your lifetime warranty.
May 08, 2009 | Blackburn Flea Rear Flasher Bicycle...
Brake lights stay on all the time
hi from uk you say b/light switch appeares to set properly ?? have removed the elec plug from switch and see if b/light go off? if they go off? then the switch is either not adjusted correctly so when pedal is released the plunger of switch is not being pushed back fully into switch and puttin lights off ? OR running into ditch?? did you press brakes in terror hard to try to avoid? the pedal may be bent slightly? giving same symptom as described above re plunger ? if remove switch and work manually with wire attached and lights stay on with plunger pressed fully in? then switch is fault? please try the above trial/s and come back with update or if you req further help ? best wishes hope this helps /
Nov 23, 2008 | 1994 Volkswagen Jetta
Blackburn Flea Light Set Logo
63 people viewed this question
Top Blackburn Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Blackburn Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
