Zenith 19'' TV Model # 19A115
I can't seem to find the video input and output on this tv. I can't believe that it doesn't have one. Could you help me find it or does it not have any.
If can't see them then it doesn't have it probably need to purchase rf unit from department store
Posted on Jan 21, 2009
Panasonic hdtv 1080i CT-36HX41E..Can you hook up a PC to the tv for the monitor?
You can connect this to your computer if you have an S-Video output on your computer. This is the only supported connection on your TV. This model doesn't have a VGA, DVI, or HDMI port.
Hope that helps!
Jul 19, 2011 | Panasonic CT-32HX40 32" TV
How do i get to the channel to watch a dvd
You will need to connect the video and audio from your DVD to the Input of the TV. So use a RCA cord to connect from the video output /audio output of the DVD player to the AV/Input/video input/audio input of the TV. Now use your remote to select the AV channel and your video and sound will come. Do this carefully . Hope you try. Good day
Aug 13, 2010 | Zenith B27A11Z 27" TV
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
How do record a movie or a live feed on a zenith vcr? we can't seem to do it
First of all, if you have a cable box for cable TV this will be first in line. Next connect the antenna in from the VCR to the cable box (or antenna system)output. Lastly, connect the output of the VCR to the RF input on the TV. With this setup you will need to tune the VCR tuner to the output channel of the cable box (ch3or4)If your TV has audio/video inputs you can connect the DVD/VCR to your TV with these cables instead of the RF cable. Your TV will have to be on ext video inputs.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 31, 2009 | Zenith Televison & Video
Zenith TV has no place for yellow, red, white composite plugs
This TV doesn't have an AV input, so there are no input jacks other than the antenna connector. If you want to connect a device that has only AV outputs (your red, white and yellow plug) you will need an RF converter. This will take the AV signals and convert them to a channel 3 or 4 signal you can tune in on the set.
But since you don't seem interested in spending any money, you'll probably not like to hear that the converter runs around $15 most places. Take heart, there is an alternative. Find a VCR (if you don't have one already) that has an RF output. Many of the the newer DVD/VCR combos only have AV outputs. You're looking for one that has an "out to TV" threaded connector on the back. These units already have an RF converter built in. Connect your AV plugs to the line in jacks on the VCR and switch to that input, and you can use your video game or DVD player through the VCR.
Jun 20, 2009 | Zenith SY2549S TV
Zenith tv, video retrace lines.
how is the 200 volt supply to the video output transistors??
measure the collector voltage of the video output transistors with the crt board on and off the crt. if voltage goes up when crt board is off then crt shorted
Apr 28, 2008 | Zenith Z25X22S 25" TV
Hooking up a dvd player
as you say that it is old tv so there is a possibility that there may not be audio video socket where dcd player can be connected. OR You will have to purchase one video RF converter.RF converter contains one video input in yellow color & two audio input in red & white colour & one cable connector as output. Connect the dvd output to this converter & tune tv program in which place you receive dvd signal.
Sep 17, 2007 | Zenith Z25X22S 25" TV
Zenith tv model sy3272dt
there should be a video input on back of the tv you can use, (red,white and yellow colors) this set I believe had more than one input. that would work for you dvd
Dec 17, 2006 | Zenith SY3272DT TV
No sound when using coax...
Do you use AV inputs for your Cable box? If so, try swapping the audio inputs in the TV, that is, interchange the AV inputs for your DVD and cable box. If sound is audible in a different input, then the Audio input (for Cable) on your TV is faulty. One simple suggestion, Why don't you route your Cable signal through the Tuner of your VCR?
Aug 08, 2006 | Zenith C19A21D 19" TV
Televison & Video Logo
Top Televison & Video Experts
