Question about Bose Audio Players & Recorders
I have an old Bose AW-1 AM/FM Stereo unit. The receiver works fine. The cassette player won't play a tape. The rewind and fast forward works OK but when, I press "PLAY" it stops within a second. Y
techman
  • 3130 Answers
SOURCE: Cassette player works fine, then screeches after 20-30 minutes.
Yeppers very common problem .. If the noise dosent come from the speakers then the problem is in the motor in the cassette deck. if the problem comes from the speakers when the deck is playing a tape, then the problem is in the record/playback switch. you may beable to fix it by spraying just a lttle bit of tuner cleaner inside the switch. It shouldnt cost much to have a repair shop do this as if you spray too much your going to ruin the belts and the mechanism. Good Luck
Posted on Jul 31, 2006
  • 93 Answers
SOURCE: CD Changer & Tape Deck
Check for dirt on CD laser lenses. Also transmission on tape player.
Posted on Oct 03, 2007
dna_killer
  • 34 Answers
SOURCE: cassette player will not work
common fault on the JVC tape decks is the belt stretch and then it does a clicking sound its trying to pick up the audio heads. changing the belt is quite hard if you have`nt done it before.
craig:)
Posted on Jan 20, 2008
SOURCE: Cassette Recorder play problem
Left(Playback) deck of cassette player turns off within about 2 sec's after inserting a cassette to play. Rewind and Fast Forward stop also after about 1 to 2 seconds. When pushing button to play it turns back off right away. I suspect the end of tape/tension sensor is the culprit but do not know where it is. Have not taken any steps except finding this site first off!
Posted on Jul 24, 2008
battlesmith
  • 382 Answers
Belts are prone to harden over time,the belt will be broken so replace it.. Also as you say the unit does turn off which is the problem of Take-up reel sensor ..Try to Take to any Service person and replace it,your player will be back in condition..Thank you..
Regards!!!...
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
Microcassette won't play but does rewind and fast forward
I have the 3 of these units at my office with the exact same problem. Turns out, with a little tinkering there is a simple fix.
Open up the unit (by unscrewing the two screws underneath) and look for a brass disk with a black rubber band around it that connects to a small tip. The rubber band should be either stretched, broken, or even melted. This is the problem. Over time the rubber band deteriorates which causes the unit to not play a tape (rewind and fast forward operate differently).
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and will be difficult to remove.
Hope this helps.
Apr 14, 2013 | Sony BM-815 / BM815 Micro Cassette...
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
Where is the rewind on this cassette player?
Cheap cassette players have no rewind feature. This allows the mechanism to be simpler and cheaper; they just 'pull' the tape forward constantly, without the pinch wheel for "fast" [sic] and with the pinch wheel for "play".
To work out if this is the problem with your cassette player, look inside with no cassette inserted. If one of the spindles is plain, without the "three-pronged" device to engage with the spool, then you have the cheap device with no rewind. Turn the tape over, and fast-forward.
Jan 19, 2011 | Audio Players & Recorders
I just purchased this system and the tape player just plays a popping sound. The tape is not moving, forwarding or playing. I have tried different tapes that play well in my other tape player. Any...
check to see if it fast forwards or rewinds. If one or none of these work, the drive belt has come off the cassette drive motor and it needs to be taken to a repair shop
Nov 28, 2010 | Electro Brand Nostalgic Stereo CD Music...
Play button no response fast forward and rewind work
THE capstain belts need changing to operrate the tape lifter mechanism
Dec 03, 2008 | JVC TD-W118 Single Cassette Deck
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
