Question about Samsung LN-S4041D 40 in. LCD HDTV
Samsung ln52a630 right side of screen blurry
Right side screen blurry on start. sometimes clears after warm up or have to smack rear of tv to clear. any ideas what is wrong
  • 113 Answers
SOURCE: My Samsung LCD TV slowly flahses colours, each about 2-4 seconds
hi,
your lcd is in test mode. you may try off the power. press and hold menu + source + power on.
this should go back to normal mode.
Posted on May 10, 2010
welcomejee
  • 10594 Answers
SOURCE: When I turn on the
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Posted on Jan 29, 2011
Mas Baz
  • 177 Answers
SOURCE: how do i clear the
Try this solution
http://www.fixya.com/support/t8339523-turn_off_display
Thanks.
Posted on Mar 18, 2011
taran_2005
  • 10515 Answers
SOURCE: PURCHASED SAMSUNG LCD TV MODEL
I am sorry to hear regarding the trouble. I understand the concern, however this is a common problem with most of the Brands. I agree that Samsung customer service should accept these facts and should be willing to help the consumers. To begin with, there is no recall for this TV and moreover, as it is more than 2 years old - it is out of warranty. What surprised me that they have mentioned you to take it to the repair shop rather than offering a repair without any labor fees. This is what most of the brands are following. I would not recommend you to take this TV to a small repair shop until they guarantee the fix. LCD display is a BIG problem on this set and i agree with the fact there is a probability that it could be a bad LCD panel. If that's the case, replacement or buying a new TV would be the best option, though i hate to choose these words.It is always advisable to buy extended warranties on these big monsters.
I would rather advise you not to give up and complaint the same with Samsung. Each manufacturer have a feedback section or customer relations. Contact them and ask for a resolution. Try to either get a replacement or repair at minimal cost.This is the only option. Opting for an outside repairman would not help as most of the outside shops keep a huge mark up on parts. If Samsung is not willing to help you, try to go a step ahead and negotiate that you are even willing to pay as most of the manufacturers take this into assumption that consumer do not want to pay for repair.Hopefully you would be able to get this rectified soon.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 12, 2011
SOURCE: I have a Samsung LCD TV LN46B650T1F and just out
I have this same issue..did you find a way to fix by replacing a board or did you buy a new tv?
Posted on Jun 21, 2011
Blurry at first then when it warms up the distortion goes away
Most of the Toshiba sets of this age had problems with a board inside that gives lines/noise left to right for several minutes and then clears up--as time goes on the warmup takes longer and longer---bad Hyper board with about 10 tiny surface mounted filter caps that dry out.
Part is not available and two options--either have a shop repair it or try it yourself---takes above average skill to remove board and replace all ten caps.
Shops will if they will attempt this usually get over 200 for the repair.
Oct 25, 2012 | Toshiba 50HX81 50" Rear Projection...
My ns-lcd42hd09 insignia tv only displays the right side of the screen clearly until the tv is on for about an hour then it will display both sides correctly. Today it never cleared up, stays really dark...
Having same problem. Smacking it or applying pressure often works. Extremely annoying (inconvenient) that a nearly $1000 machine breaks down very soon after one year ( how long the warranty is, of course)
Feb 15, 2011 | Insignia 42" LCD Flat-Panel HDTV
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Thanks.
Jan 29, 2011 | Samsung LN46A550 LCD TV
Tv looks blurry on the right side
You will also find there is colour disorientation in these areas. The reason is that your settings on the york had shifted, also it could be due to failure of the degaussing coil, or if there is any fault with the convergence inside the picture tube which could be a major fault.
Try to degauss, see the picture tube neck for any ring magnets out of alignment, also check the focussing in the rear panel which could have shifted.
Jun 08, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Lines on both sides of screen blurry images. Sometimes when I turn it on It has very bad lines, but it clears up in a few minutes.
Ur convergence is dying,well be dead,know how to solders?Must replaced convergence ICs and all it resistors.Tries websites Tv repair world.com,Tvrepairkits.com for the convergence kit.
Jan 21, 2010 | Toshiba 42H81 42" Rear Projection...
My tv is blurry. how do i get it to clear up? I
CRT tv's have a FOCUS adjustment on the flyback transformer. There may also be a "screen" adjustment on it, but you DO NOT want to turn that one.
You would have to open the tv, and take an INSULATED TOOL and turn the little adjustment labeled FOCUS or F on the flyback transformer, which is the large (usually black) thing that makes the high voltage for the CRT. It can easily be found by tracing the large red wire that has a suction cup at the top of the tube in the back. This wire goes to the top of the flyback. the focus is usually on the side of the flyback.
IMPORTANT!!!!
You must be very careful when doing this. Use a mirror to see the front of the screen while adjusting, don't reach around! Since this is the part of the TV that has LETHAL voltages you must be VERY careful not to touch anything else, since this must be done with te set turned on and warmed up.
Jun 10, 2009 | Samsung Televison & Video
Insignia flat screen
I have the same problem with my insignia.
The screen was all "pixel-ated" .
Sometimes the picture would be clear and then it would go all fuzzy.
One day in frustration I kinda smacked it. Guess what? ... the picture cleared up.
Since then about once a week I kinda have to smack the right or left side jst to the left or right of the screen.
Good luck.
Feb 04, 2008 | Televison & Video
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Samsung LN-S4041D 40 in. LCD HDTV Logo
Henry  Thomas
Henry Thomas
