Question about Intel D845GVSR Motherboard
I cannot do instaling new Windows XP OS in Harddisk
While connecting Hard disk ,If switch on computer and press del Key it is going to bios setup.and will set CD drive in to Master,that time OS is not loading in to CD.Again restart the system that time system is not going to bios.no display is comming.Some time bios display coming after that fully hanging.nothing cannot do.My hard disk is new and tested working hard disk also.Please give me a solution of this problem
    President:
  • 2,559 Answers
Restart and tap the F11 key while booting
Posted on Jan 20, 2009
I have hp pavilion dv 2000 laptop, during windows xp installtion the massage comes that setup didn't find hard disc drive installed in your computer. what is the problem???
Here is the User Guide http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Most likely the hard drive is bad.
To check power on the computer and enter BIOS by pressing F10 (Just keep hitting F10 until it enters BIOS)
Go to the system configuration menu And boot options, if no hard drive is listed then it is bad and needs to be replaced. You can attempt to unscrew the back pull out the hard drive and re seat it(plug it back in)
Also in BIOS check for Enhanced SATA mode and make sure it is off or in compatibility mode. Windows XP never shipped with SATA support and will result in a blue screen error during install. So turn off enhanced sata mode and it will run as an old IDE interface so to speak.
Jul 12, 2011 | Computers & Internet
Operating system not found Problem
Just load OS CD in to your dvd driver and restart it
  • Press any key..... when show this message
  • And do it as given instruction
Installation
*Note to wi-fi users. I recommend you use a wired connection for everything until XP is completely setup. Disable the wi-fi connection on first boot or as soon as you get the drivers installed. To disable the connection Open your Network Connection Properties, go to Start > Run > type control ncpa.cpl exactly as you see here > right-click on the wi-fi connection and choose disable.
Start your computer and insert the XP disk. If your computer supports booting from a CD you may need to change the bios startup options. The key you press to access the bios may differ depending on the make of your computer. Most use the DELETE key, if not then it will be one of the FUNCTION keys (F1, F2, etc.) Save changes and exit. If your computer does not support booting from CD then insert the first Windows XP floppy disk.
As the system boots you will see a message at the bottom of the screen:
"Press F6 if you need to install a 3rd party SCSI or RAID driver." If you do, follow the instructions.
May 22, 2011 | Computers & Internet
Hello my dear i want install 1 hard disk 320 gb and after that install win xp on my qosmio but after start setup win xp show mw did not find hard drive. how can i repair this problem? thanks
In order to be detected the hard disk drive by your windows xp installer. You have to set your sata in your cmos or bios setup. When powering your computer tap the F2 key or Del to enter cmos or bios setup, go to integrated peripherals and look for the sata controllers. Most of the times if its configured as a enhanced the windows xp can not detect it. You have to change the settings to compatible mode. Please the modify key either F5 or F6 or PGUP/PGDOWN or + or - . After changing the settings press F10 and press y and enter. Then try again running the windows setup. Have a nice day.
Feb 17, 2011 | Toshiba Qosmio G35-AV600 Notebook
I have a compaq, windows xp and the screen is black saying DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER, and the only options i can do is boot menu and setup and i don't know what else to do to...
open cpu and reconnect both connection to harddisk power cable and sata ir ide cable.
When u power up the computer press F1 or F2 or 'del" key to enter in bios then check your harddisk is detected .
This error comes when yourr hardidisk is not detected properly.
So detect your harddisk then check.
Aug 16, 2009 | Computers & Internet
My acer aspire t180 crashed a few months ago and i did not have a windows disk to reinstall it so i used the disk that i got with my dell pc(this seemed to work) but now i have bought a windows xp disk i...
Is the disk you have xp pro? If not, just do the xp home or whatever is on the disk. You may have to format your hard drive to clear it to accept the windows. Get plenty of advise before you do anything permanent like formating your hard drive. Get any factory disks that you can that will have your bios on them.
May 04, 2009 | Microsoft Windows XP Professional for PC
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Mar 25, 2009 | Acer Aspire 3680 Laptop
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
System not booting harddisk connected in master &cd drive conected in slave os win xp sp2 wts the main problem
plz set ur hardisk as the 1st boot device in the bios setup. u can enter the bios setup by pressing the del or f2 key when u power on the mission
Feb 21, 2009 | Microsoft Windows XP Professional for PC
Formating the Pc
Is the Hard Drive NEW and unused ?
If YES, XP should install no problem.
If NO,
Format with DOS boot disk and then install.
Mar 14, 2008 | Computers & Internet
Install xp in compaq presario c700
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
Intel D845GVSR Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
