Question about Fasco Staple Gun Pneumatic F3c Atw-38 Mod Range
Hi i HAVE A F3C ATW-38 ROOF S/D STAPLER AND IT HITS STAPLE IN BUT PLUNGER WONT PULL BACK UP TO SEND ANOTHER STAPLER DOWN
2 Suggested Answers
  • 13 Answers
SOURCE: I have a F3C.NC-40/50 staple gun I need
www.galino.com are a UK Fasco distributor and should be able to supply F3C parts
Posted on Mar 14, 2011
How do I free up a jammed staple in an Arrow P22 model?
Hi Francis. Remove the staples from the Arrow P22. Place a piece of wood (rod) about a quarter of an inch thick between the arms of the stapler just behind where the stapler is ejected and press down a couple of times until the jammed staple is dislodged. If the plunger is already jammed in the downward position then first pull it up and then push it down again. This procedure has worked for me on a variety of staplers over a period of very many years. Good luck!!
Feb 04, 2015 | Arrow Plier-Type Stapler - P22
I have an older Fasco stapler, it is orange in color. S3G 16 is number on it. The part that pushes out the staple has a piece of staple stuck in it. How can I get this out?
Some models have small screws on the face plate that can be unscrewed to release pressure or a spring clip to release. You can also push the plunger back into stapler with a thin narrow srewdriver, the staple may fall out.
Nov 30, 2010 | Fasco 9 Narrow Crown Pneumatic Staple Gun
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
How do you load staples in the Stanley TRA 700?
Howdy, pull out the plunger to its farthest and turn stapler upside down (staple output pointing up) and lay staples in track (in front of plunger) then push plunger back in.
Super handy when you get used to it:)
Regards, farmerbear
Sep 07, 2010 | Stanley Heavy Duty Stapler, Cast Aluminum...
Do not know how to put staples in my powershot pro
Howdy, on that model, you withdraw the plunger and turn the stapler upside down and lay the staples on the track (on the botton of stapler, not in the back) with the points facing up. When you replace the plunger, it holds them in place. I really like the reverse stapling action on that model, easier on my wrist. Hope this helps some:)
Farmerbear
Aug 30, 2010 | Powershot Tool Company Cobra 8000 Forward...
Just purchased t27 arrow staple gun but can't load staples. I have removed spring loader from rear and unsuccessfully trying to load staples from rear. Wrong method? Wrong size staples?
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
Aug 24, 2010 | Arrow Fastener T27 Light Duty Household...
Jammed staple-need to remove top of gun to remove
pull all staples out and take a screw driver and hammer drive the plunger back down into stapler till the hung staple is released
Nov 04, 2009 | Arrow T25 Staple Gun
How to put the staples
depress the handle enough to release the side catch on the stapler. now pull the bottom track down. insert a few rows of staples and snap the track back up into the stapler. the spring loaded follower goes in back of the staple stack.
Oct 20, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
Schematics on fasco air stapler #F1B 7C-16
I can e-mail you schematics. I have all Fasco & Rainco parts for this tool and more in stock!
Aug 10, 2009 | Fasco Staple Gun Pneumatic F3c Atw-38 Mod...
Stanley Pneu Roof Stapler Troubleshooting
Sorry for the delayed response, I just found this one...
The issue with depth is usually one of 2 things:
1) Insufficient pressure (bad regulator on compressor or incorrect setting).
2) Bad seals within the gun.
When was the gun last serviced? Have you looked at the O-rings for any signs of damage? All it takes is a little leakage of pressure and the plunger won't have enough thrust to set the staple as expected.
Dan
Aug 27, 2008 | Stanley Pneu Roof Stapler
Fasco Staple Gun Pneumatic F3c Atw-38 Mod Range Logo
80 people viewed this question
Top Fasco Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Fasco Tool and Hardware - Other Expert? Answer questions, earn points and help others
