Question about Canon Pixma MG5220 InkJet Printer
Canon mg 5220 blinking green and amber 21 times and pauses them blinks the pattern again
Changed the ink cartridges printed a test page and if stopped half way through the print. C000 error in the window with blinking pattern as noted. Unplugged and replugged no difference.
SOURCE: Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Aug 12, 2008
komguy
  • 2306 Answers
SOURCE: Canon ip90 4 blinks error
4 blinks is a purge unit error, that's the device that the printhead parks on on the right. Could be just a paper scrap inside, or the gears are worn out. The replacement includes the entire print engine and costs more than a new printer to replace.
Posted on Oct 07, 2009
Testimonial: "I thought this response was very knowledgeable and useful. t didn't solve by problem, but gives me a good understanding of the situation. "
komguy
  • 2306 Answers
SOURCE: Printer won't print. Green light blinks once, then
5 times says the printhead is bad and needs to be replaced.The part number is stamped on the side so you can get the right one.
Posted on Oct 30, 2009
komguy
  • 2306 Answers
SOURCE: my Canon i560 stopped printing- snall window
That error says the purge assembly is not moving properly, check for paper stuck over on the right where the printhead parks, also if the squeegee is stuck over the cleaning pads you need to push it back to allow the pads to come up properly.
Posted on Jan 10, 2010
sfigurasin
SOURCE: Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Posted on Mar 31, 2010
The color ink cartridge that is " blinking " is
Don't buy Canon as they absolutely ROB you for the ink!! They are worse than ****** dealers! At least HP allows you to use non (rip-off) OEM cartridges without all the hassle! My printer will be thrown out after the ink runs out as I will not be ripped-off by Canon again!
Apr 30, 2011 | Canon Pixma MG5220 InkJet Printer
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
My Cannon i860 is blinking an amber light five times and then returns to green then blinks amber five times and so on. What is this error telling me?
I too went through all the cleaning processes on my i860 with its amber light blinking five times to one of green. After all that time and effort, I ordered a new head, replaced it, put the old ink carts back in, and presto, worked like a charm. Don't waste time and money doing anything else.
Jul 25, 2010 | Canon i860 InkJet Photo Printer
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
Printer won't print. Green light blinks once, then turns amber & blinks 5 to 6 times, then turns green once again. I have replaced all new ink cartridges
Oct 30, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
Everytime I turn my PSC 1510 on it prints a test page, I have new cartridges in how can I stop it...it using all my ink unnecessarly:-(
yes, when you get test page face down the page on sccaner and press scan button after some time you get green light still, further u don't get test page again.
Jul 08, 2009 | HP PSC 1315 All-In-One InkJet Printer
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 won't print
The green light snable, no flashes.But test-print page is empty. All cartridges are full. Print head was reinstalled.
Sep 14, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560 printer
1. Turn off printer
May 28, 2008 | Canon BubbleJet i560 InkJet Printer
Canon Pixma MG5220 InkJet Printer Logo
old marine
old marine
