Question about Whirlpool SF367 Gas Kitchen Range
Whirlpool gas oven shuts down after cooking for extended periods
Whirlpool SF367LEMQ1 oven. Customer says it does fine for short cooking periods but shuts down for longer periods. I am assuming this is some sort of overheat protection thermostat.????
    President:
  • Whirlpool Master
  • 2,651 Answers
Id like to see it happen bfore replacin parts, but the control panel is the only "control for bake" there is no "resetable thermostat", and it uses direct spark , not an ignitor( usual suspect)..perhaps after long heating the relay on the control heats up and doesnt close correctly
Posted on Jan 20, 2009
Whirlpool super capacity 465, the over periodically doesn't light, need to restart the process multiple times, but then sometimes it works fine????? I'm puzzled
Hi Jim, when you get problems that occur periodically, then you have the beginning of things to come. Go ahead and have the board replaced and be done with it. Next thing that will happen will be that it will shut off while you are cooking something. Good luck.
Dec 15, 2014 | Whirlpool Ovens
Why doesNuwave oven shut down after one minute
How can i call customer service
chef@nuwavenow.com.If you have any questions please contact NuWave customer service at 877-689-2838 M-F 8am to 4:30pm CST. A representative will happy to assist you.
If you prefer to contact the company by
Aug 03, 2014 | Hearthware Nu-wave Pro Digital Black Oven
Whirlpool accubake oven manual
If you can supply Whirlpool with the model number, they may be able to provide a manual
Aug 19, 2013 | Ovens
Seems to cook okay, but its getting louder. What can I do?
If the sound is coming from the magnetron "heats food" it indicates failure within a short period of time. The only thing you can do is call an appliance repairman to check the oven out and verify the problem and cost.
Mar 05, 2011 | Whirlpool GH4155XP Microwave Oven
Hello. I just moved into an apt. with a Charmglow Propane Stove..Model # CGL250TE. Do I need any ventilation precautions with this stove??
Hi, any gas range or oven does not need to be vented to the outside. The reason is that this not a heating device and is meant to be used for short periods while preparing meals. People get into trouble when they try to heat the apartment by running the oven all night. If you happen to be cooking for an extended period, you may see extra condensation on the windows but opening the window a crack will help. Of course if you smell propane when your not using the stove, that would indicate a leak and should be taken care of.
Jan 12, 2010 | Williams 2509612 Ceramic Mid-Size Heater
WHIRLPOOL Sup Cap 465 oven turns on for 3 sec, then shuts off
The flame sensor is dirty or bad.
When the unit does not sense flame after ignition, the gas valve shuts down the system.
They can become corroded or dirty, but usually just need to be replaced.
Contact whirlpool for warranty info. If the unit is under warranty, they should send you the parts for free. If not, they can direct you in how to order the part.
http://www.whirlpool.com/custserv/email_form.jsp
Sep 26, 2009 | Amana AGDS902 Gas Kitchen Range
Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Whirlpool GS563LX gas range
have you tried to hold the Night Light/cook top lockout for 5 seconds?
Regards
Sir Dana Taylor
jdtaylor@live
Apr 23, 2017 | Whirlpool GS563LXS Kitchen Range
Whirlpool SF367 Gas Kitchen Range Logo
651 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
