Remove SUB-TS11 Amplifier
I can't remove the back plate / SUB-TS11 Amplifier from the subwoofer (from HKTS-11 system). There are ten screws that has been removed according to the repair guide, but also some sort of machine screw (M8*70 round head) that might has to be removed as well. However, this screw is virtually impossible to loosen. I have nudged it, but it is firm. Do I need special equipment or is there a "simple" way to remove this?
    Passionate:
    Visited the website for 10 consecutive days.
    Habit-Forming:
  • 64 Answers
Take also out the 4 "bigger" screw in each corner. It should come out without tomuch effort.
Posted on Sep 11, 2015
Did you ever manage to get the amplifier out of the casing? I'm trying to do the same thing with mine.
Posted on Aug 09, 2014
3 Suggested Answers
  • 17 Answers
SOURCE: mordaunt short ms409w subwoofer rear panel removal
You don't have to cut the speaker wires.
Under the foam wrapping is a connector - just unclip it!
Posted on Nov 29, 2010
  • 4234 Answers
SOURCE: Mackie srm350 - is there any way of replacing the
The sockets are attached to the board and teh entire back must be removed. Then the board mustbe removed from the back to gain access to the jacks. This is not a simple repair and without experience in these types of repairs, I would not suggest you attempt it. The jack itself should ony cost a few $$ and the labor should not be excessive. You may also want to investigate why the jack became loose. This is a rather unusual failure for these units.
Dan
Posted on Jan 12, 2011
How do you remove the volume knob on the Sunfire Subwoofer? Does it pull out easily or do you have to take the amplifier plate off and tighten from the inside?
I had the same problem as this, the fix was quite simple and the hum never came back.
If you pull straight out on the sub amp's volume knob it will slide off, then to fix the hum, tighten the nut that is behind the knob on the potentiometer and your hum should go away. My hum went away and never came back after this fix. Hope this helps you.
Mar 31, 2013 | Sunfire True Sub MK II Subwoofer
Hello, my Harman Kardon HKTS 15 sub woofer don'st work, the light that suppouse to turn from orange to withe when i turn on my receiver stay orange.could be the cable from my receiver to the sub...
It could be because of your subwoofer AMP is gone.
Temp fix: Disconnect the subwoofer wire from receiver for 20-30mins and plug-it back. It did work for couple of months.
Aug 22, 2011 | Harman Kardon Audio Players & Recorders
Where can I find sub board assembly for Sub-TS5. Part # 104SUB13500
If you haven't already found one, there is one currently on Amazon. It is pretty pricey at $50, though. You'd be better off buying a new sub.
http://www.amazon.com/104SUB13500-GEN-POWER-ADAPTER/dp/B004VETBPG
Aug 08, 2011 | Harman Kardon HKTS 5 System
My small son throwed so many small toys inside subwoofer. How can I open and get rid of them? Philips subwoofer.
he must have done it through the port in the front of the subwoofer.
If you look in the back of the sub woofer you will notice a metal back plate with all the sockets and controls on it. You will notic a lot of screws on it, now remember only to remove all the screws close to the edge of the metal plate ( do not remove any of the screws in the middle portion ) about 8 to 12 screws. After removing the screws pull out the metal plate gently. There will be some cables attached to the plate , do not attempt to remove this !!. Shine a torch into the box and see if you can retrieve the toys from the gap you have created by parting the back plate.
After having removed the toys place the plate back carefully making suree no wire is trapped between the box and the plate. Put two screws on the opposite ends and then lift the subwoofer and shake it to confirm if any more toys are in before you put back all the other screws.
Apr 24, 2011 | Audio Players & Recorders
I am getting no sound from sub. The turns on, but so sound. I have connected to two different receivers to verify it isn't the receiver sub output.
Bear with me on this.
Just because two systems don't light this sub up doesn't prove the amps are faultless unless they work with other subs. Can you assert that?
See page 14:
http://www.retrevo.com/support/Harman-Kardon-HKTS-14-Speaker-Systems-manual/id/386ci056/t/2/
How are you driving the sub - Speaker or Line Level?
Jan 30, 2011 | Harman Kardon HKTS 14 System
My HKTS 7 Sub woofer makes no noise,the led burns from amber to blue as normal,and every so often i hear a low rumble noise. The Sub is powered and has 1 cable to the receiver, the fuse is also good.
Subwoofer is center speaker from A+B speaker signals. first check your wire to the receiver. Otherwise you need electronics service on the amplifier inside the speaker.
Dec 04, 2010 | Harman Kardon HKTS 7 System
2003 Cadillac DTS w/Bose, has rear sub & adding Pyle dual 10 sub
two channel will do with the same power power rating of your speakers ex. your speaker is 500 watts per piece so you need to buy a 500 watts per channel amplifier
May 16, 2010 | Pyle PLHB10 Car Subwoofer
Popping harman kardon subwoofer
Mine did the same thing all of a sudden. The problem is a AC mains detection circuit that seems to affect many previous HK sub models. The solution that worked for me was to replace capacitor C112 on the main pcb of the subwoofer amplifier. You need to remove it from the circuit board with a soldering gun and replace it with a higher rated capacitor. I used a 2u2 40v and the subwoofer is working perfectly again! :)
Dec 23, 2009 | Harman Kardon HKTS 12 System
2001 ford focus stereo amp location
not all have amps.
SECTION 415-01: Audio Unit 2001 Focus Workshop Manual
REMOVAL AND INSTALLATION Subwoofer Amplifier Removal
  1. Remove the subwoofer speaker. For additional information, refer to Section 415-03 .
8 screws
  1. Remove the grill.
  1. Remove the subwoofer amplifier cover retaining screws.
  1. Disconnect the subwoofer amplifier electrical connectors.
  1. Remove the subwoofer amplifier retaining screws.
    • Remove subwoofer amplifier.
Apr 27, 2009 | 2000 Ford Focus
503 people viewed this question
 Grubhead
Grubhead
